[GRASS-user] v.in.ogr ESRI fileGDB
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 17 14:49:17 PDT 2021
Hi Rich,
I saw that you found a different solution, but just for the record: are you sure the fgdb actually contains vector data ? AFAIR, fgdb's can also contain raster data, but there is no gdal driver for that.
Moritz
Le 17 septembre 2021 19:29:37 GMT+02:00, Rich Shepard <rshepard at appl-ecosys.com> a écrit :
>On Fri, 17 Sep 2021, Maris Nartiss wrote:
>> I was testing on the main branch compiled at the end of August running
>> with GDAL 3.0.4.
>Maris,
>gdal-3.2.2 is installed here. The problem is not that.
>> Rich, you should see in the output of ogrinfo -ro -so a list of layers
>> in the FGDB. If you do not see them, then you will not be able to
>> import as GRASS is using OGR for reading FGDB.
>That's what I expected. But, From the directory in which Tile_E.gdb/ is
>located:
>$ ogrinfo -ro -so ./Tile_E.gdb/
>INFO: Open of `./Tile_E.gdb/'
> using driver `OpenFileGDB' successful.
>That's it.
>Of course GRASS could not import it since ogrinfo didn't see any content in
>the open file.
>I'll download it from the source again.
>Thanks,
>Rich
>_______________________________________________
>grass-user mailing list
>grass-user at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/grass-user
