[GRASS-user] imported .tif maps lose all data
Rich Shepard
rshepard at appl-ecosys.com
Sat Sep 25 13:09:57 PDT 2021
On Sat, 25 Sep 2021, Helmut Kudrnovsky wrote:
> try the same steps as I've done (with adjusted paths) and _post the command and the command output_ here.
> - grass78/grass80 -e -c columbia_2010_e_dtm_35.tif \grassdata\rastertest
> - enter into the location just created
Helmut,
Problem at this step:
$ grass -e -c columbia_2010_e_dtm_35.tif ./rastertest
Starting GRASS GIS...
Creating new GRASS GIS location <rastertest>...
Cleaning up temporary files...
# PROBLEM (PWD is /data/grassdata/):
$ grass rastertest
ERROR: </data/grassdata> is not a valid GRASS Location because PERMANENT Mapset is missing
Maybe you meant a different directory.
Exiting...
$ grass /data/grassdata/rastertest/
Exiting...
# The rastertest location exists with the PERMANENT mapset:
ls rastertest/PERMANENT/
DEFAULT_WIND MYNAME PROJ_INFO PROJ_UNITS PROJ_WKT VAR WIND sqlite/
So, grass here is seeing the GISDBASE as a location, even when the location
is specified on the command line with either that mapset name or the full
path?
I've been having this issue the past few weeks.
Rich
