[GRASS-user] imported .tif maps lose all data
Rich Shepard
rshepard at appl-ecosys.com
Sat Sep 25 15:54:34 PDT 2021
On Sat, 25 Sep 2021, Moritz Lennert wrote:
> The startup script expects you to provide the full path to a mapset, so
> when you give it 'data/grassdata/rastertest' it assumes that 'rastertest'
> is the mapset, so 'grassdata' must be the location. It then checks for a
> PERMANENT mapset in that location but cannot find it.
> After creating your location it only contains one single mapset:
> 'PERMANENT', so to start GRASS GIS, you have to use
> grass /data/grassdata/rastertest/PERMANENT
Moritz,
Thank you. I've forgotten that and set the PWD to the location when starting
GRASS.
I just posted the rest of the raster test and worked in the PERMANENT
mapset.
Best regards,
Rich
