[GRASS-user] Starting GRASS
Moritz Lennert
mlennert at club.worldonline.be
Sun Sep 26 08:03:07 PDT 2021
Rich,
As mentioned in an earlier mail: you have to include the mapset directory in the path.
Moritz
Le 26 septembre 2021 16:28:59 GMT+02:00, Rich Shepard <rshepard at appl-ecosys.com> a écrit :
>I don't know why I'm suddenly having problems starting GRASS when it's never
>before been an issue. I should be able to be in any directory when GRASS is
>started because ~/.grass80/rc lists the GISDBASE as /data/grassdata. I
>assume that the location in that file can be replaced by specifying the
>location onthe command line.
>But, this is not working.
>[rshepard at salmo ~]$ grass /data/grassdata/columbia_river_dtms
>Starting GRASS GIS...
>ERROR: </data/grassdata> is not a valid GRASS Location because PERMANENT Mapset is missing
>Maybe you meant a different directory.
>Exiting...
>/data/grassdata is the GISDBASE, not a location. I get the same error if the
>PWD is /data/grassdata or if I specify the fully-qualified path on the
>command line. I'm out of ideas why I'm now having these issues and a clue
>stick will be very helpful.
>TIA,
>Rich
>_______________________________________________
>grass-user mailing list
>grass-user at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/grass-user
