[GRASS-user] r.input and d.rast issues
Micha Silver
tsvibar at gmail.com
Wed Sep 29 01:50:49 PDT 2021
On 9/29/21 12:13 AM, Rich Shepard wrote:
> Since r.in.gdal followed by r.proj are not working for me, despite
> success
> with the rastertest location I applied Carlos' suggestion to use
> r.import.
> Starting GRASS from /data/grassdata/project/topography/ I applied
> r.import
> to the rastertest map, columbia_2010_e_dtm_35.tif with this result:
>> r.import
>> in=~/projects/washington/nevins-dock/data/topography/columbia_2010_e_dtm_35.tif
>> mem=6000 out=dtm35 resamp=lanczos_f ext=region resolution=region --o
> Building topology for vector map
> <tmp_r_import_region_salmo_7551 at topography>...
> Registering primitives...
> Building areas...
> 100%
> Attaching islands...
> 100%
> Attaching centroids...
> 100%
> Selected PROJ pipeline:
> +proj=pipeline +step +inv +proj=lcc +lat_0=45.3333333333333 +lon_0=-120.5
> +lat_1=47.3333333333333 +lat_2=45.8333333333333 +x_0=500000 +y_0=0
> +ellps=GRS80 +step +proj=lcc +lat_0=45.3333333333333 +lon_0=-120.5
> +lat_1=45.8333333333333 +lat_2=47.3333333333333 +x_0=500000 +y_0=0
> +ellps=GRS80 +step +proj=unitconvert +xy_in=m +xy_out=us-ft
> Reprojecting primitives ...
> <tmp_r_import_region_salmo_7551 at PERMANENT>...
> Building areas...
> 100%
> 100%
> 100%
> ERROR: Input raster does not overlap current computational region.
> Nothing
> to import.
> ERROR: Unable to import GDAL dataset
> </home/rshepard/projects/washington/nevins-dock/data/topography/columbia_2010_e_dtm_35.tif>
> I interpreted the manual page explanation of region to shift the
> output to
> that region. Do I need to set the current region to the region of the map
> I'm importing? How do I learn this before I import the .tif?
> I set the region to the raster map, local_depth:
> r.info map=local_depth
> | Map: local_depth Date: Fri Sep 24 15:49:01
> 2021 |
> | Mapset: topography Login of Creator:
> rshepard |
> | Location:
> new_nevins_dock |
> | DataBase:
> /data/grassdata |
> | Title: |
> | Timestamp:
> none |
> | Type of Map: raster Number of Categories:
> 0 |
> | Data Type: FCELL Band reference:
> (none) |
> | Rows: 15265 |
> | Columns:
> 10768 |
> | Total Cells:
> 164373520 |
> | Projection: NAD83(HARN) / Washington
> South |
> | N: 106729 S: 60934 Res:
> 3 |
> | E: 1544180 W: 1511876 Res:
> 3 |
> | Range of data: min = NULL max =
> NULL |
> | Data Description: |
> | generated by
> r.proj |
> | Comments: |
> | r.proj -n location="project/ mapset="bathymetry"
> input="local_de\ |
> | pth" method="nearest"
> memory=300 |
> but when I try to display it now GRASS tells me it cannot find the map to
> display:
> d.rast map=local_depth
> python3: can't open file
> '/data/grassdata/project/bathymetry/.tmp/salmo/MONITORS/wx0/render.py':
> [Errno 2] No such file or directory
> What might be going on here?
I think there are two things going on here:
1. You reprojected the `local_depth` raster from the topography location
to new_nevins_dock, but without setting the target mapset in advance. So
the resulting local_depth had NULL values everywhere. Regarding
projecting with r.proj, note this comment in the man page:
/"To avoid excessive time consumption when reprojecting a map the region
and resolution of the target location should be set appropriately
beforehand./
/A simple way to do this is to check the projected bounds of the input
map in the current location's projection using the////*-p*////flag.
The////*-g*////flag reports the same thing, but in a form which can be
directly cut and pasted into a//g.region
<https://grass.osgeo.org/grass78/manuals/g.region.html>command. After
setting the region in that way you might check the cell resolution with
"g.region -p" then snap it to a regular grid withg.region
<https://grass.osgeo.org/grass78/manuals/g.region.html>'s*-a*flag.
E.g.g.region -a res=5 -p. Note that this is just a rough guide./
/A more involved, but more accurate, way to do this is to generate a
vector "box" map of the region in the source location using//v.in.region
-d <https://grass.osgeo.org/grass78/manuals/v.in.region.html>. This
"box" map is then reprojected into the target location withv.proj
<https://grass.osgeo.org/grass78/manuals/v.proj.html>. Next the region
in the target location is set to the extent of the new vector map
withg.region
<https://grass.osgeo.org/grass78/manuals/g.region.html>along with the
desired raster resolution (g.region -mcan be used in Latitude/Longitude
locations to measure the geodetic length of a pixel).r.projis then run
for the raster map the user wants to reproject. In this case a little
preparation goes a long way."/
2. Then you used to `extent=` parameter to import
columbia_2010_e_dtm_35.tif only within the current computational region,
which you had set to match the raster `local_depth`. However it seems
that these do not overlap at all, so the import failed.
What does:
gdalinfo
| grep -A4 "Coordinates"
show??
Does that help?
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
