[GRASS-user] Rosetta Error in "r.fill.dir"
Nicklas Larsson n_larsson at yahoo.com
Fri Apr 22 00:06:40 PDT 2022
Daniel,
I couldn’t reproduce your issue with a random dem. It would be good if you could share a minimal data set causing the crash for testing.
Also, please take a look if there is a more detailed crash report with '/Applications/Utilities/Console.app’ and share its content.
If this is indeed a Rosetta related issue, an immediate solution would be to install the ‘grass’ port with MacPorts [1], which installs in native architecture also for M1’s.
Side note: The official GRASS Mac app bundle, is based on miniconda for its dependencies. Last time I tried there were issues with arm support for especially condas wxPython, therefore it is still only built for x64.
Best,
Nicklas
[1] https://ports.macports.org/port/grass/
> On 22 Apr 2022, at 01:16, Daniel Kozar via grass-user <grass-user at lists.osgeo.org> wrote:
> Hi everyone,
> I am trying to fill in pits in a large DEM raster (the size of USGS HUC02 "18") in GRASS 8.0. Everything works in the workflow until I get this error when I run "r.fill.dir":
> r.fill.dir input=DEM output=DEM_filled direction=DEM_dir areas=DEM_area format=agnps --overwrite
> Reading input elevation raster map...
>  100%
> Filling sinks...
> Determining flow directions for ambiguous cases...
> Found 75 unresolved areas
> Repeat to get the final directions...
> rosetta error: unexpectedly need to EmulateForward on a synchronous exception x86_rip=0x4363626336 arm_pc=0x4363681804 num_insts=6 inst_index=3 x86 instruction bytes: 0x6215344901283465301 0x17042544937633142081
> zsh: trace trap  r.fill.dir input=DEM output=DEM_filled direction=DEM_dir areas=DEM_area
> Can someone help me solve this issue? I am running GRASS 8.0 on an M1 Pro chip in MacOS Monterey. I sense this is an error with Rosetta and the M1 chip, but have not received such an error prior on this computer. I have also tried running the module through GRASS 7.6 and 7.8, but am having no luck due to segmentation fault errors.
> Best,
> Daniel Kozar
> PhD Candidate
> UC Davis - Hydrologic Sciences
> djkozar at ucdavis.edu <mailto:djkozar at ucdavis.edu>
> (814) 380-6900
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220422/f3115bbb/attachment.html>
