[GRASS-user] regex in wxGUI
Frank David
frank.david at geophom.fr
Thu Dec 1 01:22:24 PST 2022
Hi Anna,
Thank you for the trick !
By the way, do you know how to do with g.list -e rast pattern=.... ?
Regards,
Frank
Le 01/12/2022 à 05:00, Anna Petrášová a écrit :
> It's using Python regular expressions, so after some googling,
> something like this seems to work:
> ^(?:(?!string).)*$
> Seems rather complicated, maybe you can find a simpler solution...
> Anna
> On Wed, Nov 30, 2022 at 3:25 AM Frank David <frank.david at geophom.fr>
> wrote:
> Hello,
> How can I select layers in the wxGUI when using CTRL+shift+L that
> does not contain a specific string ?
> Thank you for your help.
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221201/b6a08338/attachment.htm>
