[GRASS-user] grass command to subset the columns of a vector
Frank DAVID
frank.david at geophom.fr
Tue Feb 8 23:17:20 PST 2022
Hello,
May be duplicate your file and remove the unwanted column.
Frank
Le 09/02/2022 à 01:39, Bernardo Santos via grass-user a écrit :
> Dear list,
> Is there a GRASS GIS command (maybe a v.db.* one) to subset, in a
> single command, the columns of a vector?
> What I have: vector "vect" with 5 columns "a, b, c, d, e" in the
> attribute table
> What I want: vector "vect_sub" with only, for instance, "a, c, e"
> I can use v.extract to subsample rows, but not columns. What is the
> easiest way of doing that, what needing many commands (like creating
> or copying the vector to a new one, creating a new attribute table,
> then copying only the columns I want).
> I looked for that in the documentation but did not found it so easily.
> Thanks!
> Bernardo
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220209/7bb7c198/attachment.html>
