[GRASS-user] GRASS 8 generic weekly for Linux -- startup error.
n_larsson at yahoo.com
Fri Feb 11 14:12:46 PST 2022
Hi Isaac,
This looks like something caused by ctypesgen failing to find the grass_raster.8.0 library. Not related to changes in dependencies. (Check “./configure —- help” for available configs). Please report an issue at https://github.com/OSGeo/grass/issues, for following up on this.
Best, Nicklas
On Friday, 11 February 2022, 22:30:38 CET, Isaac Ullah <iullah at sdsu.edu> wrote:
Hi all, just trying to get GRASS 8 running on my laptop (Pop!_OS 20.10) and trying the generic 64-bit Linux binaries. Made sure all dependencies are installed, etc., (done this many times before), but getting a new error upon start up. Splash screen goes, and then I get the following before the new GUI can load:Launching <wxpython> GUI in the background, please wait...
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS world_latlong_wgs84/PERMANENT:~ > Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/wxgui.py", line 86, in show_main_gui
from lmgr.frame import GMFrame
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/lmgr/frame.py", line 45, in <module>
from gui_core.preferences import MapsetAccess, PreferencesDialog
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/preferences.py", line 52, in <module>
from gui_core.dialogs import SymbolDialog, DefaultFontDialog
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/dialogs.py", line 44, in <module>
from gui_core.gselect import (
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/gselect.py", line 62, in <module>
from grass.pygrass.utils import decode
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/pygrass/utils.py", line 9, in <module>
import grass.lib.raster as libraster
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/lib/raster.py", line 30, in <module>
_libs["grass_raster.8.0"] = load_library("grass_raster.8.0")
File "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/lib/ctypes_loader.py", line 89, in __call__
raise ImportError("Could not load %s." % libname)
ImportError: Could not load grass_raster.8.0.
^C
GRASS world_latlong_wgs84/PERMANENT:~ > exit
exit
WARNING: Failed to start shell '/bin/bash'
Cleaning up default sqlite database ...
Cleaning up temporary files...
Done.
Goodbye from GRASS GIS
Seems like something to do with the GRASS 8 raster library? Is there a new dependency not listed in https://grass.osgeo.org/grass80/binary/linux/snapshot/REQUIREMENTS.html ? Any thoughts? FYI, I was able to run the two release candidates on the same OS (but different computer).
~Isaac
___________________________________________________________________________Isaac I. Ullah, PhD
Associate Professor of Anthropology
Anthropology Undergraduate Adviser San Diego State University
Office: AL 480Book an advising appointment via SDSU Navigate (T,Th 12-1p)This email account is checked before 4pm on business days. Allow several days for response.
Recent papers:"Laborscapes and Archaeologies of Sustainability" PDF download
"Water, dust, and loess: co-evolution of landscapes, farming, and human society" PDF download
"Modeling feedbacks between human and natural processes in the land system" PDF download
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220211/8aec13f8/attachment.html>
