[GRASS-user] GRASS 8 generic weekly for Linux -- startup error.
Isaac Ullah
iullah at sdsu.edu
Fri Feb 11 15:07:48 PST 2022
Thanks Niklas! Yes, I'll file the bug report. Hopefully it's a relatively
easy fix...
Isaac
Sent from my📱
On Fri, Feb 11, 2022, 2:12 PM <n_larsson at yahoo.com> wrote:
> Hi Isaac,
> This looks like something caused by ctypesgen failing to find the
> grass_raster.8.0 library. Not related to changes in dependencies. (Check
> “./configure —- help” for available configs). Please report an issue at
> https://github.com/OSGeo/grass/issues, for following up on this.
> Best, Nicklas
> On Friday, 11 February 2022, 22:30:38 CET, Isaac Ullah <iullah at sdsu.edu>
> wrote:
> Hi all, just trying to get GRASS 8 running on my laptop (Pop!_OS 20.10)
> and trying the generic 64-bit Linux binaries. Made sure all dependencies
> are installed, etc., (done this many times before), but getting a new error
> upon start up. Splash screen goes, and then I get the following before the
> new GUI can load:
> Launching <wxpython> GUI in the background, please wait...
> To run a command as administrator (user "root"), use "sudo <command>".
> See "man sudo_root" for details.
> GRASS world_latlong_wgs84/PERMANENT:~ > Traceback (most recent call last):
> File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
> lambda event: event.callable(*event.args, **event.kw) )
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/wxgui.py",
> line 86, in show_main_gui
> from lmgr.frame import GMFrame
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/lmgr/frame.py",
> line 45, in <module>
> from gui_core.preferences import MapsetAccess, PreferencesDialog
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/preferences.py",
> line 52, in <module>
> from gui_core.dialogs import SymbolDialog, DefaultFontDialog
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/dialogs.py",
> line 44, in <module>
> from gui_core.gselect import (
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/gui/wxpython/gui_core/gselect.py",
> line 62, in <module>
> from grass.pygrass.utils import decode
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/pygrass/utils.py",
> line 9, in <module>
> import grass.lib.raster as libraster
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/lib/raster.py",
> line 30, in <module>
> _libs["grass_raster.8.0"] = load_library("grass_raster.8.0")
> File
> "/usr/local/grass8.0.1dev-x86_64-pc-linux-gnu-11_02_2022/etc/python/grass/lib/ctypes_loader.py",
> line 89, in __call__
> raise ImportError("Could not load %s." % libname)
> ImportError: Could not load grass_raster.8.0.
> ^C
> GRASS world_latlong_wgs84/PERMANENT:~ > exit
> exit
> WARNING: Failed to start shell '/bin/bash'
> Cleaning up default sqlite database ...
> Cleaning up temporary files...
> Done.
> Goodbye from GRASS GIS
> Seems like something to do with the GRASS 8 raster library? Is there a new
> dependency not listed in
> https://grass.osgeo.org/grass80/binary/linux/snapshot/REQUIREMENTS.html ?
> Any thoughts? FYI, I was able to run the two release candidates on the same
> OS (but different computer).
> ~Isaac
> ___________________________________________________________________________
> Isaac I. Ullah, PhD
> *Associate Professor of Anthropology*
> *Anthropology Undergraduate Adviser*
> *San Diego State University *
> *Office: AL 480*
> Book an advising appointment via SDSU Navigate
> <https://sdsu.campus.eab.com/> (T,Th 12-1p)
> *This email account is checked before 4pm on business days. Allow several
> days for response.*
> *Recent papers:*
> "Laborscapes and Archaeologies of Sustainability" PDF download
> <http://www.academia.edu/download/60027293/chessonetal201920190716-17471-11xg82p.pdf>
> "Water, dust, and loess: co-evolution of landscapes, farming, and human
> society" PDF download
> <https://www.researchgate.net/profile/Claudia_Chang/publication/333635247_Water_dust_and_agro-pastoralism_Modeling_socio-ecological_co-evolution_of_landscapes_farming_and_human_society_in_southeast_Kazakhstan_during_the_mid_to_late_Holocene/links/5cf84e43a6fdcc847508a08c/Water-dust-and-agro-pastoralism-Modeling-socio-ecological-co-evolution-of-landscapes-farming-and-human-society-in-southeast-Kazakhstan-during-the-mid-to-late-Holocene.pdf>
> "Modeling feedbacks between human and natural processes in the land
> system" PDF download
> <https://research.birmingham.ac.uk/portal/files/50636814/Robinson_et_al_Modelling_feedbacks_Earth_Syst._Dynam._2018.pdf>
> <https://doi.org/10.5194/esd-9-895-2018>
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220211/25b2e464/attachment-0001.html>
