[GRASS-user] Mini project 2022: Week 6: Redesigning a map display status bar combo box into a new settings dialog
Linda Kladivová
L.Kladivova at seznam.cz
Sun Feb 13 22:22:26 PST 2022
Hello guys,
I am sending my sixth weekly report, it is also available here [1].
1) What did I complete this week?
This week was mostly about finishing PR [2] which projects all changes to
other Map Display applications. I am still working on combobox removal and
moving stuff to Map Display settings [3]. Some problems have occured here -
we need to take into account two things: other Map Display apps with a
different number of elements in statusbar combobox and possible dynamic
change of elements in statusbar combobox (when switching to 3D). Both these
things complicate the task. In the meantime, I fixed a bug caused by [2] in
[4] and improved statusbar update when 'Use defined projection' toggled [5].
2) What am I going to achieve for next week?
The main task for the next week is to finish the PR for combobox removal
(https://github.com/OSGeo/grass/pull/2153)[2]. There is still quite much
work to do. On Sunday I also worked on a new icon for Map Display settings
so I plan to open another PR for that.
3) Is there any blocking issue?
No, it isn't.
Have a nice week.
Linda
[1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
(https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar)
[2] https://github.com/OSGeo/grass/pull/2155
(https://github.com/OSGeo/grass/pull/2155)
[3] https://github.com/OSGeo/grass/pull/2153
[4] https://github.com/OSGeo/grass/pull/2190
(https://github.com/OSGeo/grass/pull/2190)
[5] https://github.com/OSGeo/grass/pull/2178
(https://github.com/OSGeo/grass/pull/2178)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220214/2788482a/attachment.html>
