[GRASS-user] 8 Release Candidate
Anna Petrášová
kratochanna at gmail.com
Sun Jan 23 19:36:31 PST 2022
On Sun, Jan 23, 2022 at 9:41 AM Randal Hale <rjhale at northrivergeographic.com>
wrote:
> I've been trying to run the 8 release candidate. I'm on a stock Ubuntu
> (21.10) install and I've downloaded the binary 8 release candidate for
> grass. I do have Grass 7.8.5 running.
> Anyway - I've installed in a custom location and in the default. I start
> grass and get. The GRASS Splash screen does come up and stays up for about
> 2 secs and then I'm sitting at the prompt. I can't get the GUI up and
> running. Thoughts (I can file a bug report if needed):
> ./grass
> Starting GRASS GIS...
> Cleaning up temporary files...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 8.0.0dev (4d15e3313)
> GRASS GIS homepage: https://grass.osgeo.org
> This version running through: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> See citation options with: g.version -x
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> Launching <wxpython> GUI in the background, please wait...
> To run a command as administrator (user "root"), use "sudo <command>".
> See "man sudo_root" for details.
> GRASS world_latlong_wgs84/PERMANENT:bin > Traceback (most recent call last):
> File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
> lambda event: event.callable(*event.args, **event.kw) )
> File "/home/rjhale/temp/grass/gui/wxpython/wxgui.py", line 86, in show_main_gui
> from lmgr.frame import GMFrame
> File "/home/rjhale/temp/grass/gui/wxpython/lmgr/frame.py", line 45, in <module>
> from gui_core.preferences import MapsetAccess, PreferencesDialog
> File "/home/rjhale/temp/grass/gui/wxpython/gui_core/preferences.py", line 52, in <module>
> from gui_core.dialogs import SymbolDialog, DefaultFontDialog
> File "/home/rjhale/temp/grass/gui/wxpython/gui_core/dialogs.py", line 44, in <module>
> from gui_core.gselect import (
> File "/home/rjhale/temp/grass/gui/wxpython/gui_core/gselect.py", line 62, in <module>
> from grass.lib.imagery import (
> File "/home/rjhale/temp/grass/etc/python/grass/lib/imagery.py", line 30, in <module>
> _libs["grass_imagery.8.0"] = load_library("grass_imagery.8.0")
> File "/home/rjhale/temp/grass/etc/python/grass/lib/ctypes_loader.py", line 89, in __call__
> raise ImportError("Could not load %s." % libname)
> ImportError: Could not load grass_imagery.8.0.
I just pushed a fix [1], so the GUI should at least start now, but I don't
know why grass can't load the library. So some functionality still won't
work (e.g. 3D, digitizer).
Anna
[1] https://github.com/OSGeo/grass/pull/2120
> Randal Halerjhale at northrivergeographic.comhttps://www.northrivergeographic.com
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220123/5d138b54/attachment.html>
