[GRASS-user] 8 Release Candidate
Randal Hale rjhale at northrivergeographic.com
Mon Jan 24 12:10:31 PST 2022
Thanks! Just got back to this - I'll test it out.
Randy
On 1/23/22 22:36, Anna Petrášová wrote:
> On Sun, Jan 23, 2022 at 9:41 AM Randal Hale
> <rjhale at northrivergeographic.com> wrote:
>     I've been trying to run the 8 release candidate. I'm on a stock
>     Ubuntu (21.10) install and I've downloaded the binary 8 release
>     candidate for grass. I do have Grass 7.8.5 running.
>     Anyway - I've installed in a custom location and in the default. I
>     start grass and get. The GRASS Splash screen does come up and
>     stays up for about 2 secs and then I'm sitting at the prompt. I
>     can't get the GUI up and running. Thoughts (I can file a bug
>     report if needed):
>     ./grass
>     Starting GRASS GIS...
>     Cleaning up temporary files...
>                __________  ___   __________    _______________
>               / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>              / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>             / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>             \____/_/ |_/_/  |_/____/____/   \____/___//____/
>     Welcome to GRASS GIS 8.0.0dev (4d15e3313)
>     GRASS GIS homepage:https://grass.osgeo.org
>     This version running through:            Bash Shell (/bin/bash)
>     Help is available with the command:      g.manual -i
>     See the licence terms with:              g.version -c
>     See citation options with:               g.version -x
>     If required, restart the GUI with:       g.gui wxpython
>     When ready to quit enter:                exit
>     Launching <wxpython> GUI in the background, please wait...
>     To run a command as administrator (user "root"), use "sudo <command>".
>     See "man sudo_root" for details.
>     GRASS world_latlong_wgs84/PERMANENT:bin > Traceback (most recent call last):
>        File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
>          lambda event: event.callable(*event.args, **event.kw  <http://event.kw>) )
>        File "/home/rjhale/temp/grass/gui/wxpython/wxgui.py", line 86, in show_main_gui
>          from lmgr.frame import GMFrame
>        File "/home/rjhale/temp/grass/gui/wxpython/lmgr/frame.py", line 45, in <module>
>          from gui_core.preferences import MapsetAccess, PreferencesDialog
>        File "/home/rjhale/temp/grass/gui/wxpython/gui_core/preferences.py", line 52, in <module>
>          from gui_core.dialogs import SymbolDialog, DefaultFontDialog
>        File "/home/rjhale/temp/grass/gui/wxpython/gui_core/dialogs.py", line 44, in <module>
>          from gui_core.gselect import (
>        File "/home/rjhale/temp/grass/gui/wxpython/gui_core/gselect.py", line 62, in <module>
>          from grass.lib.imagery import (
>        File "/home/rjhale/temp/grass/etc/python/grass/lib/imagery.py", line 30, in <module>
>          _libs["grass_imagery.8.0"] = load_library("grass_imagery.8.0")
>        File "/home/rjhale/temp/grass/etc/python/grass/lib/ctypes_loader.py", line 89, in __call__
>          raise ImportError("Could not load %s." % libname)
>     ImportError: Could not load grass_imagery.8.0.
> Hi,
> I just pushed a fix [1], so the GUI should at least start now, but I
> don't know why grass can't load the library. So some functionality
> still won't work (e.g. 3D, digitizer).
> Anna
> [1] https://github.com/OSGeo/grass/pull/2120
>     Randal Hale
>     https://www.northrivergeographic.com
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/grass-user
Randal Hale
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220124/4f44ff7d/attachment.html>
