[GRASS-user] NULL values as output of i.atcorr
Ilaria Ferrando
ilaria.ferrando87 at gmail.com
Wed Jan 26 10:50:50 PST 2022
Dear Māris,
Thank you for your reply.
Yes, the image is inside the computational region.
Any other ideas?
Il mer 26 gen 2022, 19:45 Maris Nartiss <maris.gis at gmail.com> ha scritto:
> One thing to always check – does your computational region contain
> data you are analysing? Try to run `g.region rast=immagine` before
> running i.atcorr.
> Māris.
> trešd., 2022. g. 26. janv., plkst. 18:13 — lietotājs
> <ilaria.ferrando87 at gmail.com> rakstīja:
> > Dear all,
> > I am having troubles in processing a Sentinel-2 image with i.atcorr.
> > The command I use is the following:
> > i.atcorr -r -input=immagine at mapset range=0,10000
> parameters=C:\...\22giugno2020_b4.txt output=immagine_atcorr rescale=0,1
> > and I obtain this output:
> > wavelength less than 0.25 micron:
> > let's take s(l)=s(0.25)
> > Atmospheric correction...
> > Atmospheric correction complete.
> > The map I obtain is constituted by pixels with 6.669033e-34 values.
> > Can anyone explain the meaning of the output and why I obtain a NULL
> value corrected map?
> > Thank you for your support.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220126/ba981ea1/attachment.html>
