[GRASS-user] NULL values as output of i.atcorr
Maris Nartiss maris.gis at gmail.com
Wed Jan 26 10:44:52 PST 2022
One thing to always check – does your computational region contain
data you are analysing? Try to run `g.region rast=immagine` before
running i.atcorr.
Māris.
trešd., 2022. g. 26. janv., plkst. 18:13 — lietotājs
<ilaria.ferrando87 at gmail.com> rakstīja:
> Dear all,
> I am having troubles in processing a Sentinel-2 image with i.atcorr.
> The command I use is the following:
> i.atcorr -r -input=immagine at mapset range=0,10000 parameters=C:\...\22giugno2020_b4.txt output=immagine_atcorr rescale=0,1
> and I obtain this output:
> wavelength less than 0.25 micron:
> let's take s(l)=s(0.25)
> Atmospheric correction...
> Atmospheric correction complete.
> The map I obtain is constituted by pixels with 6.669033e-34 values.
> Can anyone explain the meaning of the output and why I obtain a NULL value corrected map?
> Thank you for your support.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
