[GRASS-user] NULL values as output of i.atcorr
    ilaria.ferrando87 at gmail.com
    Wed Jan 26 08:13:05 PST 2022
Dear all,
I am having troubles in processing a Sentinel-2 image with i.atcorr.
The command I use is the following:
i.atcorr -r -input=immagine at mapset range=0,10000
parameters=C:\...\22giugno2020_b4.txt output=immagine_atcorr rescale=0,1
and I obtain this output:
wavelength less than 0.25 micron:
let's take s(l)=s(0.25)
Atmospheric correction...
Atmospheric correction complete.
The map I obtain is constituted by pixels with 6.669033e-34 values.
Can anyone explain the meaning of the output and why I obtain a NULL value
corrected map?
Thank you for your support.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220126/ed16e9db/attachment.html>
