[GRASS-user] MacOS - Georectifier unable advance beyond source map type / location selection
    Anna Petrášová
    kratochanna at gmail.com
    Fri Jun 10 05:50:37 PDT 2022
Hi all,
it would be great to report this as an issue so that we don't forget about
it and it can be fixed:
https://github.com/OSGeo/grass/issues/new/choose
Thank you
Anna
On Tue, Jun 7, 2022 at 2:55 PM Robert Dzur <rdzur at bhinc.com> wrote:
> Dr. Statella,
> Thanks for the workaround suggestion.  That worked on my Mac OS install.
> Appreciate your kind assistance.
> Rob
> *Robert S. Dzur*
> Sr. Vice President and Systems Manager Spatial Data
> *Bohannan Huston*
> *p.* 505.823.1000 *|* *d.* 505.798.7966 *| **c.* 505.235.7786
> *Connect*: bhinc.com <http://www.bhinc.com/> | Facebook
> <https://www.facebook.com/bohannanhuston/> | LinkedIn
> <https://www.linkedin.com/company/bohannan-huston-inc-/> | Twitter
> <https://twitter.com/BohannanHuston>
> *Building great teams to support great communities. Want to be part of the
> team? Visit **bhinc.com/careers* <https://bhinc.com/careers>
> DISCLAIMER: This e-mail, including attachments, may include confidential
> and/or proprietary information and may be used only by the person or entity
> to which it is addressed. Any unauthorized review, use, disclosure, or
> dissemination is strictly prohibited. If you received this e-mail in error,
> please notify the sender by reply e-mail and delete this e-mail immediately.
> *From: *Thiago Statella <t.statella at outlook.com>
> *Date: *Tuesday, June 7, 2022 at 12:47 PM
> *To: *Robert Dzur <rdzur at bhinc.com>
> *Cc: *grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
> *Subject: *Re: [GRASS-user] MacOS - Georectifier unable advance beyond
> Hi, Rob
> I had the same issue. In my case, a workaround was directly type the name
> of the mapset and hit next button.
> I hope it helps!
> Atenciosamente,
> Dr. Thiago Statella, professor Titular
> Instituto Federal de Educação, Ciência e Tecnologia de Mato Grosso - IFMT
> Campus de Cuiabá, Depto. de Infraestrutura
> Rua Prof. Zulmira Canavarros 93, Centro
> CEP: 78605-200, Tel: +55 65 3318-1400
> http://lattes.cnpq.br/8559753273123798
> https://sites.google.com/view/statella
> http://www.researcherid.com/rid/B-5196-2011
> Em 7 de jun. de 2022, à(s) 14:02, Robert Dzur <rdzur at bhinc.com> escreveu:
> Hello list,
> I’m having some trouble getting past the setup screen with the
> Georectifier on an M1 Max MacBook Pro running the latest 8.2.0 (June 6)
> release.
> I have a fairly rudimentary setup where I have imported a tiff image into
> an XY mapset to perform rough georeferencing of that image against a vector
> dataset in a UTM (EPSG:6341) mapset.  Both mapsets are under a common GRASS
> GIS database path.
> When I attempt to launch the georectifier from the UTM mapset and select
> the source data in the XY database I get the following message:
> You must select a valid location and mapset in order to continue
> I cannot seem to get past this setup screen with the Next button pictured
> below:
> <image001.png>
> Incidentally, I had this issue on prior 8x MacOS versions.  However, if I
> take the same GRASS GIS database (both mapsets) created under MacOS, to a
> Windows machine (running GRASS GIS 8.0.1); I have no issues running the
> Greorectifier.
> Has anyone else come across this issue or might there be a work around on
> the Mac that I’m missing?
> Thank you for any suggestions.
> Best,
> Rob
> *Robert S. Dzur*
> *Bohannan Huston*
> <https://nam12.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.bhinc.com%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=%2BcB8qv%2BChpBt4HDe7pQYbv3s8mvTUJHJdQBht90gJic%3D&reserved=0>
>  | Facebook
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.facebook.com%2Fbohannanhuston%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=towv2vhC4ACxC1OgwTjl6SwHgM6EuvcxvdUvLuQwvXk%3D&reserved=0>
>  | LinkedIn
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.linkedin.com%2Fcompany%2Fbohannan-huston-inc-%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=6aBfzUBYGTJVDZQeAnocqRJJLINCt45shhl8jGS8yvo%3D&reserved=0>
>  | Twitter
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftwitter.com%2FBohannanHuston&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=MX27keGyaZpQaj32zWQKE57ORohzn4Ty7HtY7Kke6jQ%3D&reserved=0>
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fbhinc.com%2Fcareers&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Qqnk3WrUCfPqZh86%2FsGkRtSZWVtmycSGAeMCZfNoJvQ%3D&reserved=0>
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220610/4953182a/attachment-0001.htm>
