[GRASS-user] MacOS - Georectifier unable advance beyond source map type / location selection
Robert Dzur
rdzur at bhinc.com
Fri Jun 10 06:20:26 PDT 2022
Thank you Anna. I submitted this as a new issue: https://github.com/OSGeo/grass/issues/2424
Best,
Rob
Sent: Friday, June 10, 2022 6:51 AM
To: Robert Dzur <rdzur at bhinc.com>
Cc: Thiago Statella <t.statella at outlook.com>; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] MacOS - Georectifier unable advance beyond source map type / location selection
Hi all,
it would be great to report this as an issue so that we don't forget about it and it can be fixed:
https://github.com/OSGeo/grass/issues/new/choose
Thank you
Anna
On Tue, Jun 7, 2022 at 2:55 PM Robert Dzur <rdzur at bhinc.com<mailto:rdzur at bhinc.com>> wrote:
Dr. Statella,
Thanks for the workaround suggestion. That worked on my Mac OS install.
Appreciate your kind assistance.
Rob
Robert S. Dzur
Sr. Vice President and Systems Manager Spatial Data
Bohannan Huston
p. 505.823.1000 | d. 505.798.7966 | c. 505.235.7786
Connect: bhinc.com<http://www.bhinc.com/> | Facebook<https://www.facebook.com/bohannanhuston/> | LinkedIn<https://www.linkedin.com/company/bohannan-huston-inc-/> | Twitter<https://twitter.com/BohannanHuston>
Building great teams to support great communities. Want to be part of the team? Visit bhinc.com/careers<https://bhinc.com/careers>
DISCLAIMER: This e-mail, including attachments, may include confidential and/or proprietary information and may be used only by the person or entity to which it is addressed. Any unauthorized review, use, disclosure, or dissemination is strictly prohibited. If you received this e-mail in error, please notify the sender by reply e-mail and delete this e-mail immediately.
From: Thiago Statella <t.statella at outlook.com<mailto:t.statella at outlook.com>>
Date: Tuesday, June 7, 2022 at 12:47 PM
To: Robert Dzur <rdzur at bhinc.com<mailto:rdzur at bhinc.com>>
Cc: grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org> <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Hi, Rob
I had the same issue. In my case, a workaround was directly type the name of the mapset and hit next button.
I hope it helps!
Atenciosamente,
Dr. Thiago Statella, professor Titular
Instituto Federal de Educação, Ciência e Tecnologia de Mato Grosso - IFMT
Campus de Cuiabá, Depto. de Infraestrutura
Rua Prof. Zulmira Canavarros 93, Centro
CEP: 78605-200, Tel: +55 65 3318-1400
http://lattes.cnpq.br/8559753273123798
https://sites.google.com/view/statella
http://www.researcherid.com/rid/B-5196-2011
Em 7 de jun. de 2022, à(s) 14:02, Robert Dzur <rdzur at bhinc.com<mailto:rdzur at bhinc.com>> escreveu:
Hello list,
I’m having some trouble getting past the setup screen with the Georectifier on an M1 Max MacBook Pro running the latest 8.2.0 (June 6) release.
I have a fairly rudimentary setup where I have imported a tiff image into an XY mapset to perform rough georeferencing of that image against a vector dataset in a UTM (EPSG:6341) mapset. Both mapsets are under a common GRASS GIS database path.
When I attempt to launch the georectifier from the UTM mapset and select the source data in the XY database I get the following message:
You must select a valid location and mapset in order to continue
I cannot seem to get past this setup screen with the Next button pictured below:
<image001.png>
Incidentally, I had this issue on prior 8x MacOS versions. However, if I take the same GRASS GIS database (both mapsets) created under MacOS, to a Windows machine (running GRASS GIS 8.0.1); I have no issues running the Greorectifier.
Has anyone else come across this issue or might there be a work around on the Mac that I’m missing?
Thank you for any suggestions.
Best,
Rob
Robert S. Dzur
Bohannan Huston
Connect: bhinc.com<https://nam12.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.bhinc.com%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=%2BcB8qv%2BChpBt4HDe7pQYbv3s8mvTUJHJdQBht90gJic%3D&reserved=0> | Facebook<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.facebook.com%2Fbohannanhuston%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=towv2vhC4ACxC1OgwTjl6SwHgM6EuvcxvdUvLuQwvXk%3D&reserved=0> | LinkedIn<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.linkedin.com%2Fcompany%2Fbohannan-huston-inc-%2F&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=6aBfzUBYGTJVDZQeAnocqRJJLINCt45shhl8jGS8yvo%3D&reserved=0> | Twitter<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftwitter.com%2FBohannanHuston&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=MX27keGyaZpQaj32zWQKE57ORohzn4Ty7HtY7Kke6jQ%3D&reserved=0>
Building great teams to support great communities. Want to be part of the team? Visit bhinc.com/careers<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fbhinc.com%2Fcareers&data=05%7C01%7C%7C937fd65e1b244970189208da48afea66%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637902217659545094%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Qqnk3WrUCfPqZh86%2FsGkRtSZWVtmycSGAeMCZfNoJvQ%3D&reserved=0>
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220610/42dedc74/attachment-0001.htm>
