[GRASS-user] about geomorphon pattern
    Veronica Andreo
    veroandreo at gmail.com
    Mon Jun 27 02:04:14 PDT 2022
Hello Ueda,
Indeed there's no pattern.txt in the source code of r.geomorphon, and it
was also not there when the module was moved from addons to core. The only
pattern file is a c file. Maybe a typo in the manual page? Did you have a
look at the pattern.c file?
Vero
El dom, 26 jun 2022 a las 15:05, Mitsunori Ueda (<inkyo.3215 at gmail.com>)
escribió:
> Hi GRASS GIS mailing list
> Regarding r.geomorphon,
> in the ternary pattern of the analysis result,
> there is a description in the manual that you want to see pattern.txt in
> the source code directory to see all the patterns.
> However, there is no file named pattern.txt in the code directory.
> If you know the location of the file,
> could you please tell me?
> Thank you.
> Ueda
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220627/6c0e558f/attachment.htm>
