[GRASS-user] about geomorphon pattern
Mitsunori Ueda inkyo.3215 at gmail.com
Mon Jun 27 22:18:20 PDT 2022
Hello Veronica
Thank you for replying to my email.
I have not checked the file yet.
I will check it.
Thank you.
Ueda
2022年6月27日(月) 18:04 Veronica Andreo <veroandreo at gmail.com>:
> Hello Ueda,
> Indeed there's no pattern.txt in the source code of r.geomorphon, and it
> was also not there when the module was moved from addons to core. The only
> pattern file is a c file. Maybe a typo in the manual page? Did you have a
> look at the pattern.c file?
> Vero
> El dom, 26 jun 2022 a las 15:05, Mitsunori Ueda (<inkyo.3215 at gmail.com>)
> escribió:
>> Hi GRASS GIS mailing list
>> Regarding r.geomorphon,
>> in the ternary pattern of the analysis result,
>> there is a description in the manual that you want to see pattern.txt in
>> the source code directory to see all the patterns.
>> However, there is no file named pattern.txt in the code directory.
>> If you know the location of the file,
>> could you please tell me?
>> Thank you.
>> Ueda
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220628/7c66a356/attachment.htm>
