I'm working on the command line with the development version. I have a vector area map called 'permit_area' in the PERMANENT mapset. When I check using 'g.list type=vect' the map name is displayed. But, when I ask g.proj or v.info to tell me about that map they tell me 'permit_area not found.' What might cause this behavior? TIA, Rich
