[GRASS-user] Map not found?
Anna Petrášová
kratochanna at gmail.com
Tue May 2 08:12:35 PDT 2023
Could you show the exact commands and output? Are you sure it's not a typo?
On Tue, May 2, 2023 at 10:06 AM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> I'm working on the command line with the development version.
> I have a vector area map called 'permit_area' in the PERMANENT mapset.
> When I
> check using 'g.list type=vect' the map name is displayed. But, when I ask
> g.proj or v.info to tell me about that map they tell me 'permit_area not
> found.'
> What might cause this behavior?
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230502/3592fcf5/attachment.htm>
