[GRASS-user] Map not found?
Rich Shepard rshepard at appl-ecosys.com
Tue May 2 08:22:20 PDT 2023
On Tue, 2 May 2023, Anna Petrášová wrote:
> Could you show the exact commands and output? Are you sure it's not a typo?
Anna,
GRASS NSR_TaxLot/PERMANENT:~ > g.mapsets -p
Accessible mapsets:
PERMANENT
GRASS NSR_TaxLot/PERMANENT:~ > g.list type=vect
permit_area
GRASS NSR_TaxLot/PERMANENT:~ > g.proj -g georef=permit_area
ERROR 4: permit_area: No such file or directory
ERROR: Unable to read georeferenced file <permit_area> using GDAL library
GRASS NSR_TaxLot/PERMANENT:~ > v.info map=pernit_area
ERROR: Vector map <pernit_area> not found
g.list finds the vector file in the PERMANENT mapset so I expected to learn
details using g.proj and v.info.
Regards,
Rich
