[GRASS-user] Map not found?
Anna Petrášová kratochanna at gmail.com
Tue May 2 08:26:59 PDT 2023
On Tue, May 2, 2023 at 11:22 AM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Tue, 2 May 2023, Anna Petrášová wrote:
> > Could you show the exact commands and output? Are you sure it's not a
> typo?
> Anna,
> GRASS NSR_TaxLot/PERMANENT:~ > g.mapsets -p
> Accessible mapsets:
> PERMANENT
> GRASS NSR_TaxLot/PERMANENT:~ > g.list type=vect
> permit_area
> GRASS NSR_TaxLot/PERMANENT:~ > g.proj -g georef=permit_area
georef doesn't expect a GRASS map, but a georeferenced file.
ERROR 4: permit_area: No such file or directory
> ERROR: Unable to read georeferenced file <permit_area> using GDAL library
> GRASS NSR_TaxLot/PERMANENT:~ > v.info map=pernit_area
> ERROR: Vector map <pernit_area> not found
it's a typo
> g.list finds the vector file in the PERMANENT mapset so I expected to learn
> details using g.proj and v.info.
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230502/bc7abe35/attachment.htm>
