[GRASS-user] Map not found?
Anna Petrášová
kratochanna at gmail.com
Tue May 2 08:29:30 PDT 2023
Rich, perhaps you want to consider asking these questions on Gitter?
https://gitter.im/grassgis/community
I think it's better suited for these questions.
On Tue, May 2, 2023 at 11:26 AM Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, May 2, 2023 at 11:22 AM Rich Shepard <rshepard at appl-ecosys.com>
> wrote:
>> On Tue, 2 May 2023, Anna Petrášová wrote:
>> > Could you show the exact commands and output? Are you sure it's not a
>> typo?
>> Anna,
>> GRASS NSR_TaxLot/PERMANENT:~ > g.mapsets -p
>> Accessible mapsets:
>> PERMANENT
>> GRASS NSR_TaxLot/PERMANENT:~ > g.list type=vect
>> permit_area
>> GRASS NSR_TaxLot/PERMANENT:~ > g.proj -g georef=permit_area
> georef doesn't expect a GRASS map, but a georeferenced file.
> ERROR 4: permit_area: No such file or directory
>> ERROR: Unable to read georeferenced file <permit_area> using GDAL library
>> GRASS NSR_TaxLot/PERMANENT:~ > v.info map=pernit_area
>> ERROR: Vector map <pernit_area> not found
> it's a typo
>> g.list finds the vector file in the PERMANENT mapset so I expected to
>> learn
>> details using g.proj and v.info.
>> Regards,
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230502/dedc535f/attachment-0001.htm>
