[GRASS-user] Is this a bug in 8.3.dev? [RESOLVED]
Rich Shepard
rshepard at appl-ecosys.com
Fri May 5 07:06:34 PDT 2023
On Fri, 5 May 2023, Rich Shepard wrote:
> If the re-installation of numpy doesn't fix the problem I build and
> install the 8.2.2 source which will replace the development code
> installed. I must get hydrological analyses done by Monday so I don't
> really care which grass version I run.
Markus, et al.:
To my pleasant surprise, re-building/re-installing python3-numpy-1.22.3
fixed the monitor issue. The only reason that comes to mind is that the
first install was in parallel with python2 and python2-numpy and grass was
still looking for the latter even though it was gond and the laptop
rebooted.
I've run Slackware for 20 years now and haven't had this issue with any
SlackBuilds.org packages before. Regardless I can now meet client
expectations.
Thanks for pointing me in the right direction.
I have a question about a multi-layer FileGDB where each layer has a
different CRS and I'll aske that on gitter.
Regards,
Rich
