[GRASS-user] v.in.ascii syntax help needed
    Markus Neteler
    neteler at osgeo.org
    Tue May  9 06:04:47 PDT 2023
Rich,
On Tue, May 9, 2023 at 2:40 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Tue, 9 May 2023, Maris Nartiss wrote:
> > On the first row you have specified a line with 5 coordinates and one
> > category (L 5 1). You have not provided the last line containing that one
> > category. Just add „1 1“ (layer 1, cat 1) as a last row and you should be
> > fine.
> Māris.
> Thank you. I searched the manual page to learn what the first and last lines
> in the example meant, but didn't find what they represent.
> So, on the top line 'L' means to draw lines, '5' means 5 data rows, and '1'
> means one category. And on the bottom line the layer and category number are
> defined.
> I'll add a recommendation to add these explanations to the manual page on
> the bug/feature request web page.
Please consider to edit the page right away:
https://github.com/OSGeo/grass/blob/main/vector/v.in.ascii/v.in.ascii.html
In the upper right of the page is a pen symbol. Then you can submit it
as a pull request by saving the changes.
Thanks
Markus
PS: Manual improvements  are always welcome!
