[GRASS-user] v.to.rast: advice needed [RESOLVED]
Rich Shepard rshepard at appl-ecosys.com
Wed May 10 08:14:48 PDT 2023
On Wed, 10 May 2023, Rich Shepard wrote:
> Which v.db* should I use to find the elevation colum associated with each
> contour line?
Long ago I used the GUI and it had a menu to examine the vector map's table.
Now, I just leared that v.db.select will work. There're more columns than I
need, but one does have the elevation data. Back to work ...
Rich
