[GRASS-user] ps.map: specifying colors
Rich Shepard
rshepard at appl-ecosys.com
Mon May 15 10:19:03 PDT 2023
On Mon, 15 May 2023, Vaclav Petras wrote:
> The r:g:b format supports 0-255, not the hexadecimal colors, so that's why
> ff does not work. With display commands, you can also use #rrggbb
> (#RRGGBB). I would have to check if that works with ps.map or not.
Vaclav,
I should know that. Perhaps need to recaffinate. Yes, the color chart I used
has hexidecimal numbers.
Many thanks,
Rich
