[GRASS-user] v.in.ascii data error
    Rich Shepard
    rshepard at appl-ecosys.com
    Mon May 22 11:46:46 PDT 2023
On Mon, 22 May 2023, Anna Petrášová wrote:
>> Data file:
>> B 5
>>   45.654023|-122.980241|393|Shop
>>   45.653931|-122.980315|393|Shop
>>   45.653960|-122.979910|393|Shop
>>   45.653856|-122.979831|393|Shop
> you are mixing formats, either use 'standard' or 'point', see the
> v.in.ascii manual. Likely you need format=point.
Anna,
I know that lines and points use the point format, but boundaries and areas
use the standard format. Your comment informs me that a boundary or area
without a specified centroid is imported in point format and becomes an area
after v.centroid is applied.
I didn't think of this.
Many thanks,
Rich
