[GRASS-user] v.in.ascii data error
Anna Petrášová
kratochanna at gmail.com
Mon May 22 13:44:29 PDT 2023
On Mon, May 22, 2023 at 2:47 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Mon, 22 May 2023, Anna Petrášová wrote:
> >> Data file:
> >> B 5
> >> 45.654023|-122.980241|393|Shop
> >> 45.653931|-122.980315|393|Shop
> >> 45.653960|-122.979910|393|Shop
> >> 45.653856|-122.979831|393|Shop
> > you are mixing formats, either use 'standard' or 'point', see the
> > v.in.ascii manual. Likely you need format=point.
> Anna,
> I know that lines and points use the point format, but boundaries and areas
> use the standard format. Your comment informs me that a boundary or area
> without a specified centroid is imported in point format and becomes an
> area
> after v.centroid is applied.
That's not what I meant. Point format is for points, nothing else. If you
need areas, you need standard format. See the first example in the man page
for importing areas.
> I didn't think of this.
> Many thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230522/b7e77733/attachment.htm>
