[GRASS-user] Trying to use GRASS with Jupyter note books in Windows
Vishal Mehta
vishalm1975 at gmail.com
Wed Sep 27 18:17:27 PDT 2023
I'm trying to follow this setup:
https://github.com/ncsu-geoforall-lab/GIS714-assignments/blob/main/GRASS_GIS_Foundations/JupyterOnWindows_Tutorial.ipynb
I have stand-alone GRASS GIS 8.3 installed in Windows in C:\GRASS GIS 8.3
I followed the 7 setup steps (changing set path to reflect that its
installed in C:\GRASS GIS 8.3
Then when i run this first part:
import os
import subprocess
import sys
# Ask GRASS GIS where its Python packages are.
sys.path.append(
subprocess.check_output(["grass", "--config", "python_path"],
text=True).strip()
# Import GRASS packages
import grass.script as gs
import grass.jupyter as gj
I get the following error:
---------------------------------------------------------------------------FileNotFoundError
Traceback (most recent call last)
Cell In[1], line 7 3 import sys 5 # Ask GRASS GIS where its
Python packages are. 6 sys.path.append(----> 7
text=True).strip() 8 ) 10 # Import GRASS packages 11
File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:424, in
check_output(timeout, *popenargs, **kwargs) 421 empty = b''
422 kwargs['input'] = empty--> 424 return run(*popenargs,
stdout=PIPE, timeout=timeout, check=True, 425
**kwargs).stdout
File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:505, in run(input,
capture_output, timeout, check, *popenargs, **kwargs) 502
kwargs['stdout'] = PIPE 503 kwargs['stderr'] = PIPE--> 505 with
Popen(*popenargs, **kwargs) as process: 506 try: 507
stdout, stderr = process.communicate(input, timeout=timeout)
File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:951, in
Popen.__init__(self, args, bufsize, executable, stdin, stdout, stderr,
preexec_fn, close_fds, shell, cwd, env, universal_newlines,
startupinfo, creationflags, restore_signals, start_new_session,
pass_fds, user, group, extra_groups, encoding, errors, text, umask)
947 if self.text_mode: 948 self.stderr =
io.TextIOWrapper(self.stderr, 949
encoding=encoding, errors=errors)--> 951 self._execute_child(args,
executable, preexec_fn, close_fds, 952
pass_fds, cwd, env, 953 startupinfo,
creationflags, shell, 954 p2cread,
p2cwrite, 955 c2pread, c2pwrite, 956
errread, errwrite, 957
restore_signals, 958 gid, gids, uid, umask,
959 start_new_session) 960 except:
961 # Cleanup if the child failed starting. 962 for f in
filter(None, (self.stdin, self.stdout, self.stderr)):
File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:1420, in
Popen._execute_child(self, args, executable, preexec_fn, close_fds,
pass_fds, cwd, env, startupinfo, creationflags, shell, p2cread,
p2cwrite, c2pread, c2pwrite, errread, errwrite,
unused_restore_signals, unused_gid, unused_gids, unused_uid,
unused_umask, unused_start_new_session) 1418 # Start the process
1419 try:-> 1420 hp, ht, pid, tid =
_winapi.CreateProcess(executable, args, 1421
# no special security 1422 None,
None, 1423 int(not close_fds), 1424
creationflags, 1425
env, 1426 cwd, 1427
startupinfo) 1428 finally: 1429 # Child is
launched. Close the parent's copy of those pipe 1430 # handles
that only the child should have open. You need (...) 1433 #
pipe will not close when the child process exits and the 1434 #
ReadFile will hang. 1435 self._close_pipe_fds(p2cread, p2cwrite,
1436 c2pread, c2pwrite, 1437
errread, errwrite)
FileNotFoundError: [WinError 2] The system cannot find the file specified
Can someone help figure out what the issue is?
Thanks,
Vishal
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230927/f2808ebd/attachment-0001.htm>
