[GRASS-user] Trying to use GRASS with Jupyter note books in Windows
Vaclav Petras
wenzeslaus at gmail.com
Wed Sep 27 20:22:15 PDT 2023
Hi Vishal,
The executable on Windows is not called "grass" like on Linux but "grass8"
or "grass83" (to avoid a strange Python import error). That should do the
trick. If not, try simply providing a full path yourself including the
extension (C:\...\...bat).
Best,
Vaclav
On Wed, 27 Sept 2023 at 21:20, Vishal Mehta via grass-user <
grass-user at lists.osgeo.org> wrote:
> I'm trying to follow this setup:
> https://github.com/ncsu-geoforall-lab/GIS714-assignments/blob/main/GRASS_GIS_Foundations/JupyterOnWindows_Tutorial.ipynb
> I have stand-alone GRASS GIS 8.3 installed in Windows in C:\GRASS GIS 8.3
> I followed the 7 setup steps (changing set path to reflect that its
> installed in C:\GRASS GIS 8.3
> Then when i run this first part:
> import os
> import subprocess
> import sys
> # Ask GRASS GIS where its Python packages are.
> sys.path.append(
> subprocess.check_output(["grass", "--config", "python_path"],
> text=True).strip()
> # Import GRASS packages
> import grass.script as gs
> import grass.jupyter as gj
> I get the following error:
> ---------------------------------------------------------------------------FileNotFoundError Traceback (most recent call last)
> Cell In[1], line 7 3 import sys 5 # Ask GRASS GIS where its Python packages are. 6 sys.path.append(----> 7 subprocess.check_output(["grass", "--config", "python_path"], text=True).strip() 8 ) 10 # Import GRASS packages 11 import grass.script as gs
> File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:424, in check_output(timeout, *popenargs, **kwargs) 421 empty = b'' 422 kwargs['input'] = empty--> 424 return run(*popenargs, stdout=PIPE, timeout=timeout, check=True, 425 **kwargs).stdout
> File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:505, in run(input, capture_output, timeout, check, *popenargs, **kwargs) 502 kwargs['stdout'] = PIPE 503 kwargs['stderr'] = PIPE--> 505 with Popen(*popenargs, **kwargs) as process: 506 try: 507 stdout, stderr = process.communicate(input, timeout=timeout)
> File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:951, in Popen.__init__(self, args, bufsize, executable, stdin, stdout, stderr, preexec_fn, close_fds, shell, cwd, env, universal_newlines, startupinfo, creationflags, restore_signals, start_new_session, pass_fds, user, group, extra_groups, encoding, errors, text, umask) 947 if self.text_mode: 948 self.stderr = io.TextIOWrapper(self.stderr, 949 encoding=encoding, errors=errors)--> 951 self._execute_child(args, executable, preexec_fn, close_fds, 952 pass_fds, cwd, env, 953 startupinfo, creationflags, shell, 954 p2cread, p2cwrite, 955 c2pread, c2pwrite, 956 errread, errwrite, 957 restore_signals, 958 gid, gids, uid, umask, 959 start_new_session) 960 except: 961 # Cleanup if the child failed starting. 962 for f in filter(None, (self.stdin, self.stdout, self.stderr)):
> File C:\GRASS GIS 8.3\Python39\lib\subprocess.py:1420, in Popen._execute_child(self, args, executable, preexec_fn, close_fds, pass_fds, cwd, env, startupinfo, creationflags, shell, p2cread, p2cwrite, c2pread, c2pwrite, errread, errwrite, unused_restore_signals, unused_gid, unused_gids, unused_uid, unused_umask, unused_start_new_session) 1418 # Start the process 1419 try:-> 1420 hp, ht, pid, tid = _winapi.CreateProcess(executable, args, 1421 # no special security 1422 None, None, 1423 int(not close_fds), 1424 creationflags, 1425 env, 1426 cwd, 1427 startupinfo) 1428 finally: 1429 # Child is launched. Close the parent's copy of those pipe 1430 # handles that only the child should have open. You need (...) 1433 # pipe will not close when the child process exits and the 1434 # ReadFile will hang. 1435 self._close_pipe_fds(p2cread, p2cwrite, 1436 c2pread, c2pwrite, 1437 errread, errwrite)
> FileNotFoundError: [WinError 2] The system cannot find the file specified
> Can someone help figure out what the issue is?
> Thanks,
> Vishal
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230927/17254716/attachment.htm>
