[GRASS-user] Integer division with r.mapcalc
Ondřej Pešek pesej.ondrek at gmail.com
Thu Apr 11 00:49:19 PDT 2024
Hi Luís,
čt 11. 4. 2024 v 8:26 odesílatel Luí­s Moreira de Sousa via grass-user
<grass-user at lists.osgeo.org> napsal:
> I am working with a raster with very large integers. That are stored as 64 bit floats (imported from a GTiff). I wish to extract part of these values with an integer division. The first approach was:
> r.mapcalc 'short_ints = int(long_ints)/1000000'
> However, this results in something that is not an integer division. In fact I have no idea what the result is. Eventually, I succeeded with the following formulation:
> r.mapcalc 'psu_ids = int(ssu_ids/1000000)'
> I have been going through the manual back and forth and can't understand why these two expressions produce different results. Any insights?
This is probably due to the 32-bit size of `int()`. If your values are
higher than `2 ** 31 -1` (i.e. 214783467; `31` because half of the
numbers go to the negatives; `-1` because there is also NULL), the
counter starts to rotate. It means that `2 ** 31` will be NULL and `2
** 31 + 1` will be `- (2 ** 31 - 1)`. You can encounter this behaviour
also in other software, such as in `numpy`.
Indeed, there is no mention of that in the docs. I will update it
today to include this information. It is true that it's easy to break
your teeth on this.
Cheers,
Ondra
