[GRASS-user] Using RStudio in a GRASS GIS session
sibylle.stoeckli at gmx.ch
Wed Apr 17 11:34:32 PDT 2024
Dear community
To use RStudio in a GRASS GIS session I used the command line
GRASS> rstudio &
library(rgrass)
(see https://grasswiki.osgeo.org/wiki/R_statistics/rgrass)
Unfortunately I was not able to solve the error message:
- The command "GRASS" is either misspelled or
could not be found.
- The command "library" is either misspelled or
could not be found.
Kind regards
Sibylle
(Wed Apr 17 20:25:17 2024)
GRASS> rstudio &
Der Befehl "GRASS" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
(Wed Apr 17 20:25:17 2024) Command ended with non-zero return code 1 (0 sec)
(Wed Apr 17 20:25:29 2024)
library(rgrass)
Der Befehl "library" ist entweder falsch geschrieben oder
(Wed Apr 17 20:25:29 2024) Command ended with non-zero return code 1 (0 sec)
