[GRASS-user] Using RStudio in a GRASS GIS session
sibylle.stoeckli at gmx.ch
Thu Apr 18 11:02:25 PDT 2024
Dear Veronica and Micha
Find enclosed some info about the operative system:
System Info
GRASS version: 8.3.2
Code revision: 695385bb79
Build date: 2024-03-07
Build platform: x86_64-w64-mingw32
GDAL: 3.8.4
PROJ: 9.3.1
GEOS: 3.12.1
SQLite: 3.41.1
Python: 3.9.18
wxPython: 4.2.1
Platform: Windows-10-10.0.19045-SP0
Similarly when using library(rgrass) the same error: "library" is either misspelled or
could not be found.
library(rgrass)
Der Befehl "library" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
(Thu Apr 18 19:59:40 2024) Command ended with non-zero return code 1 (0 sec)
Kind regards
Sibylle
Sent: Thursday, April 18, 2024 7:56 PM
To: Micha Silver <tsvibar at gmail.com>
Cc: sibylle.stoeckli at gmx.ch; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Using RStudio in a GRASS GIS session
Hello Sibylle,
Perhaps you can tell us some details about your operative system, which GRASS installer you are using (i.e., standalone or OSGeo4W), how did you start GRASS, if R and RStudio are installed.
>From your email, I do not understand why GRASS is not recognized as a command, as it seems you **are** already within a GRASS session on the terminal? (i.e. you have a GRASS prompt there `GRASS>`).
Vero
El jue, 18 abr 2024 a las 12:06, Micha Silver via grass-user (<grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> >) escribió:
Silly question, do you have the 'rgrass' library installed?
i.e. can you do `library(rgrass)` at the R command prompt (without rstudio)?
On 17/04/2024 21:34, sibylle via grass-user wrote:
Dear community
To use RStudio in a GRASS GIS session I used the command line
GRASS> rstudio &
library(rgrass)
(see https://grasswiki.osgeo.org/wiki/R_statistics/rgrass)
Unfortunately I was not able to solve the error message:
- The command "GRASS" is either misspelled or
could not be found.
- The command "library" is either misspelled or
could not be found.
Kind regards
Sibylle
(Wed Apr 17 20:25:17 2024)
GRASS> rstudio &
Der Befehl "GRASS" ist entweder falsch geschrieben oder
(Wed Apr 17 20:25:17 2024) Command ended with non-zero return code 1 (0 sec)
(Wed Apr 17 20:25:29 2024)
library(rgrass)
(Wed Apr 17 20:25:29 2024) Command ended with non-zero return code 1 (0 sec)
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240418/0c76d357/attachment-0001.htm>
