[GRASS-user] Is ther a quick way to install grass8.3.2 in Ubuntu Jammy?
    Veronica Andreo
    veroandreo at gmail.com
    Sat Aug  3 11:12:22 PDT 2024
Hi Amedeo
We just released 8.4, and it is here
<https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=>.
Basically, you install the repo, update and install grass, something like:
  sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
  sudo apt-get update
  sudo apt-get install grass grass-gui grass-dev
Then, for the plugin, you can customize which grass version it uses:
Plugins > GRASS > GRASS Options. Under General you can change the version
used to whatever you have.
HTH, I'm not the most knowledgeable person about Ubuntu...
Vero
El sáb, 3 ago 2024 a las 13:40, Amedeo Fadini AF via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hiu everybody, with some update I've broken my installation of QGIS 3.38
> and GRASS 7,8,7
> Now it seems that qgis-grass-plugin requires grass 8.3.2 but the pachage
> is not available in ubuntugis...
> I'm not (yet) enaough confindent to use GRASS outside QGIS and I really
> need a quick solution to have this stack working.
> I'm testing a workflow  that translates sea-polyogns digitized with some
> reference coastine so they can match another refernce coastline: scripting
> and topological editing is mandatory so GRASS GIS will be the right tool.
> Thank-you very much for your support.
> Amedeo Fadini
> Pianificatore Territoriale
> Iscritto all'albo della provincia di Treviso al n. 3100
> www.amefad.it
> cell 328 2671141
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240803/578bb406/attachment.htm>
