[GRASS-user] Is ther a quick way to install grass8.3.2 in Ubuntu Jammy?
    Amedeo Fadini AF
    amedeo at amefad.it
    Sun Aug  4 03:12:31 PDT 2024
Thank-you Veronica for the reply,
Yes I've already update to 8.4 but aptitude refuse to install
qgis-plugin-grass
her is the apt output:
The following packages have unmet dependencies:
 qgis-plugin-grass : Depends: grass832 but it is not installable
I think it's a problem on qgis side, or maybe the ubuntugis repository
needs to be aligned...
I've asked here too  just in case someone else has the same environment.
Well It will be a good choice to learn using GRASS GIS from CLI :-)
Amedeo
Il giorno sab 3 ago 2024 alle ore 20:12 Veronica Andreo <
veroandreo at gmail.com> ha scritto:
> Hi Amedeo
> We just released 8.4, and it is here
> <https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=>.
> Basically, you install the repo, update and install grass, something like:
>   sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>   sudo apt-get update
>   sudo apt-get install grass grass-gui grass-dev
> Then, for the plugin, you can customize which grass version it uses:
> Plugins > GRASS > GRASS Options. Under General you can change the version
> used to whatever you have.
> HTH, I'm not the most knowledgeable person about Ubuntu...
> Vero
> El sáb, 3 ago 2024 a las 13:40, Amedeo Fadini AF via grass-user (<
> grass-user at lists.osgeo.org>) escribió:
>> Hiu everybody, with some update I've broken my installation of QGIS 3.38
>> and GRASS 7,8,7
>> Now it seems that qgis-grass-plugin requires grass 8.3.2 but the pachage
>> is not available in ubuntugis...
>> I'm not (yet) enaough confindent to use GRASS outside QGIS and I really
>> need a quick solution to have this stack working.
>> I'm testing a workflow  that translates sea-polyogns digitized with some
>> reference coastine so they can match another refernce coastline: scripting
>> and topological editing is mandatory so GRASS GIS will be the right tool.
>> Thank-you very much for your support.
>> Amedeo Fadini
>> Pianificatore Territoriale
>> Iscritto all'albo della provincia di Treviso al n. 3100
>> www.amefad.it
>> cell 328 2671141
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Dra. Verónica Andreo
> Investigadora Adjunta de CONICET
> Instituto Gulich (CONAE - UNC)
> Centro Espacial Teófilo Tabanera (CETT)
> Falda del Cañete - Córdoba, Argentina
> +54 3547 400000 int. 1153
> https://veroandreo.gitlab.io/
Amedeo Fadini
www.amefad.it
cell 328 2671141
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240804/02854502/attachment.htm>
