[GRASS-user] Multidirectional hillshading scripts / addons?
Carlos Henrique Grohmann de Carvalho
carlos.grohmann at gmail.com
Sat Feb 17 06:33:42 PST 2024
WhiteBox is another option (there is a QGIS plugin)
https://www.whiteboxgeo.com/manual/wbt_book/available_tools/geomorphometric_analysis.html#MultidirectionalHillshade
Carlos
On Sat, Feb 17, 2024 at 10:44 AM Paulo van Breugel via grass-user <
grass-user at lists.osgeo.org> wrote:
> Hi,
> Not sure about grass gis, but have you tried the multidirectional option
> when styling a raster as a hillshade in QGIS? See
> https://bnhr.xyz/2019/01/22/hillshade-in-qgis.html.
> Cheers,
> Paulo
> On Fri, Feb 16, 2024 at 11:20 PM B H via grass-user <
>> Hi,
>> I am trying to create a hillshading effect using DEM rasters similar to
>> ESRI multidirectional hillshading, but I am unable to get anything in.
>> grass to perform as good as ESRI (or even gdaldem multidirectional shading).
>> I am hoping someone in this group has some scripts /addon/tips that I can
>> try.
>> So far I have tried the following on a few DEMs ( from 3m to 100 m grid
>> sizes).
>> 1) gdaldem multidirectional hillshading : It's not grass based, but so
>> far has performed better than other grass options : with the parameter
>> zfactor between 1 and 10. But it does not seem to be quite as good as ESRI.
>> 2) Following code is based on some old discussion on this email list.(Its
>> seems to exaggerate the hills and valleys more than I would expect)
>> https://gist.github.com/amcox/b54d65f08fe4448840462901fd6350d4
>> 3) Other variants of hillshading like r.skyview : Tried with several
>> parameters but it seems to be inferior to gdaldem (It seems to be a 'washed
>> out' version of the multidirectional. hillshading).
>> Thanks,
>> HB
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
Editor-in-Chief - Brazilian Journal of Geology
http://carlosgrohmann.com
https://spamlab.github.io/
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240217/a436171d/attachment.htm>
