[GRASS-user] Multidirectional hillshading scripts / addons?
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Feb 17 05:43:27 PST 2024
Not sure about grass gis, but have you tried the multidirectional option
when styling a raster as a hillshade in QGIS? See
https://bnhr.xyz/2019/01/22/hillshade-in-qgis.html.
Cheers,
Paulo
On Fri, Feb 16, 2024 at 11:20 PM B H via grass-user <
grass-user at lists.osgeo.org> wrote:
> Hi,
> I am trying to create a hillshading effect using DEM rasters similar to
> ESRI multidirectional hillshading, but I am unable to get anything in.
> grass to perform as good as ESRI (or even gdaldem multidirectional shading).
> I am hoping someone in this group has some scripts /addon/tips that I can
> try.
> So far I have tried the following on a few DEMs ( from 3m to 100 m grid
> sizes).
> 1) gdaldem multidirectional hillshading : It's not grass based, but so
> far has performed better than other grass options : with the parameter
> zfactor between 1 and 10. But it does not seem to be quite as good as ESRI.
> 2) Following code is based on some old discussion on this email list.(Its
> seems to exaggerate the hills and valleys more than I would expect)
> https://gist.github.com/amcox/b54d65f08fe4448840462901fd6350d4
> 3) Other variants of hillshading like r.skyview : Tried with several
> parameters but it seems to be inferior to gdaldem (It seems to be a 'washed
> out' version of the multidirectional. hillshading).
> Thanks,
> HB
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240217/3bb25f92/attachment.htm>
