[GRASS-user] Convert vector to STVDS
Veronica Andreo
veroandreo at gmail.com
Tue Feb 27 12:54:14 PST 2024
Hello Ken,
Sorry for such a late reply. AFAIU and some old experience with STVDS, the
approach is by date, i.e., you need a map per date. This is because of the
snapshot logic of STDS. I remember having done animations with vector time
series, but again, that was a long time ago. Have you tried calling the
list of vector maps instead of the stvds? At least to understand if it is a
temporal or spatial topology issue.
There was also a QGIS plugin by Soeren to visually explore STDS (
https://www.youtube.com/watch?v=xxHt3jJbnYw), and IIUC the time manager of
QGIS required only a vector file with a date field to show animations.
Best,
Vero
El sáb, 2 dic 2023 a las 14:56, Ken Mankoff via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hi List,
> On 2023-12-01 at 16:30 -08, Ken Mankoff <mankoff at gmail.com> wrote...
> > I have a vector with 115284 lines. From db.select I see
> > | cat | ID | Date |
> > | 1 | 278 | 1990-07-10 |
> > | 2 | 278 | 1992-07-30 |
> > | 3 | 278 | 1994-08-29 |
> > | 4 | 242 | 1998-06-05 |
> > | 5 | 255 | 2005-03-03 |
> > That is, 115284 cats and 291 IDs.
> Using just one ID to start with (with 80 timestamps) I've created 80
> vectors, each with their own layer and v.timestamp. I can then patch these
> together to one product with multiple layers.
> If I t.register all of these, I also see what I expect to see with
> g.gui.timeline. If I run "g.gui.animation stvds=t" it reports "Topology
> [...] is invalid".
> Is there a way to export STVDs and see the time component in QGIS or
> KMZ/Google Earth?
> Thanks,
> -k.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240227/d81087b0/attachment.htm>
