[GRASS-user] how to add a loop in the graphical modeler
    Javier Garcia Prieto
    fjgarciaprieto at hotmail.com
    Sat Jan  6 04:12:22 PST 2024
Hello.
I'm Javier García Prieto from México.
I do exactly the same as you intend to do years ago.
There are 2 ways to do what you want frim my perspective.
1 If you are working in Linux do a bash script to import every raster to grass, then execute your model from that script.
https://thedbadmin.com/how-to-loop-in-bash-linux-shell-script-automation/
https://grasswiki.osgeo.org/wiki/Importing_data#:~:text=Create%20a%20new%20location%20for,raster%20data%20(internally%20using%20GDAL)
2 Use Python to do the same in a way that the script is system agnostic. Once you have aquired your maps in grass use your model as described above.
Greetings from Mexico.
Enviado desde mi LG de Telcel.
------ Mensaje original------
Desde: Victor Lundström via grass-user
Fecha: sáb., 6 ene. 2024 4:17
Para: grass-user;
Cc:
Asunto:[GRASS-user] how to add a loop in the graphical modeler
Hi everyone,
I'm trying the start getting familiar with the graphical modeler as I have a lot of raster operations that I need to automate.
I have 456 raster layers that I (1) want to interpolate using v.surf.bspline, and then (2) export to six different folders, 76 rasters for each.
I have designed the workflow in the graphical modeler using just one layer to see that everything works the way that it should, and it does!
However, I can't for the life of me figure out how to set up a loop so that it can iterate through all the remaining layers. I'm trying my best to
read the manual, but since all of this is new to me, I can't figure out (1) how to add several raster layers. Whenever I use the "add data to model" I can
only add one layer from the drop down list. I also don't know if I need two loops, one for interpolation and then one for the raster export.
I have attached a screenshot that outlines my model. I hope you'll be able to guide me in the right direction!
Best,
Victor
[cid:50d4456d-7068-4914-87ef-b733b6be741a]
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240106/ba3d128b/attachment-0001.htm>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240106/ba3d128b/attachment-0001.png>
