[GRASS-user] how to add a loop in the graphical modeler
    Ondřej Pešek
    pesej.ondrek at gmail.com
    Sat Jan  6 11:01:14 PST 2024
Hi Victor,
You can do it as Javier said. However, if you really wish to do everything
in the modeler, you can do so, but the loops in the modeler are optimized
for data already in GRASS and thus it would be sort of clumsy.
You define your models using a variable, for example %map as I did for my
r.in.gdal:
[image: Screenshot from 2024-01-06 19-32-44.png]
Then you can define a loop using the "Add loop/series to model" button (or
Model -> Add loop / series). If the maps were already imported, you could
automatically loop through them based on a pattern. As there are outside,
you would need to write all of them manually (or copy from some list of
yours) which is pretty annoying but possible (see the field "Condition" in
the example below):
[image: Screenshot from 2024-01-06 19-33-46.png]
That's it, just choose all your modules to be included in the loop.
However, I would recommend also another way that's easy even if you don't
feel Pythonist enough. As you already have your model defined, you could
use the "Python editor" tab and you already have your Python script that
needs just minimal changes. So if my model consisting of r.in.gdal and
r.out.gdal produced this Python script:
import sys
import os
import atexit
from grass.script import parser, run_command
def cleanup():
    pass
def main(options, flags):
    run_command("r.in.gdal",
                input="input_raster",
                output="imported_raster",
                memory=300,
                offset=0,
                num_digits=0)
    run_command("r.out.gdal",
                input="imported_raster",
                output="raster_output",
                format="GTiff",
                overviews=0)
    return 0
if __name__ == "__main__":
    options, flags = parser()
    atexit.register(cleanup)
    sys.exit(main(options, flags))
I would just need to change it to the following. Please note the extra
`import glob`, `for` loop, indentation change, and variables used in
r.in.gdal[input] and r.out.gdal[output]. Naturally, you could also change
the intermediate map names based on the `file_path` variable if you wish so:
import sys
import os
import atexit
import glob
def cleanup():
    pass
    for file_path in glob.glob('your_data_path/*'):
                    input=file_path,
                    memory=300,
                    offset=0,
                    num_digits=0)
                    output=os.path.join("your_output_dir",
os.path.basename(file_path)),
                    format="GTiff",
                    overviews=0)
    return 0
Cheers.
so 6. 1. 2024 v 11:17 odesílatel Victor Lundström via grass-user <
grass-user at lists.osgeo.org> napsal:
> Hi everyone,
> I'm trying the start getting familiar with the graphical modeler as I have
> a lot of raster operations that I need to automate.
> I have 456 raster layers that I (1) want to interpolate using
> v.surf.bspline, and then (2) export to six different folders, 76 rasters
> for each.
> I have designed the workflow in the graphical modeler using just one layer
> to see that everything works the way that it should, and it does!
> However, I can't for the life of me figure out how to set up a loop so
> that it can iterate through all the remaining layers. I'm trying my best to
> read the manual, but since all of this is new to me, I can't figure out
> (1) how to add several raster layers. Whenever I use the "add data to
> model" I can
> only add one layer from the drop down list. I also don't know if I need
> two loops, one for interpolation and then one for the raster export.
> I have attached a screenshot that outlines my model. I hope you'll be able
> to guide me in the right direction!
> Best,
> Victor
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240106/7e0002d3/attachment-0001.htm>
Name: Screenshot from 2024-01-06 19-32-44.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240106/7e0002d3/attachment-0002.png>
Name: Screenshot from 2024-01-06 19-33-46.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240106/7e0002d3/attachment-0003.png>
