[GRASS-user] Installing addons in GRASS 8.2.0 - Ubuntu 22.04.3 LTS
Edouard Choinière
e.chs at outlook.com
Mon Jan 15 15:08:45 PST 2024
Hi!
This problem seems to have been fixed proactively 10 months ago in https://github.com/OSGeo/grass/pull/2895 <https://github.com/OSGeo/grass/pull/2895> and released in Grass 8.3.0 on June 24. 2023.
GitHub announced last year that it was sunsetting SVN protocol access, and has been sunset on January 8 2024. So it’s expected that the installation using an now in existing url won’t work.
<https://github.blog/2023-01-20-sunsetting-subversion-support/>
[Product at 2x.png]
Sunsetting Subversion support<https://github.blog/2023-01-20-sunsetting-subversion-support/>
github.blog<https://github.blog/2023-01-20-sunsetting-subversion-support/>
<https://github.blog/changelog/2024-01-08-subversion-has-been-sunset/>
Subversion has been sunset<https://github.blog/changelog/2024-01-08-subversion-has-been-sunset/>
github.blog<https://github.blog/changelog/2024-01-08-subversion-has-been-sunset/>
[cropped-github-favicon-512.png]<https://github.blog/changelog/2024-01-08-subversion-has-been-sunset/>
Apart from using 8.3.0+, like from https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable, I don’t remember the specific workaround to specify an alternative url that won’t use the SVN code path for code stored in GitHub.
Can someone step in?
Edouard Choinière
Le 15 janv. 2024 à 07:52, Mario Reyes <ernestoreyes561 at gmail.com> a écrit :
I want to install the r.clip addon in Ubuntu 22.04.3 LTS. I am using GRASS 8.2.0, installed from https://launchpad.net/%7Eubuntugis/+archive/ubuntu/ppa. I also installed svn and grass-dev. When I use g.extension I get the following error:
g.extension r.clip
/usr/lib/grass82/scripts/g.extension:167: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.dir_util import copy_tree
Fetching <r.clip> from GRASS GIS Addons repository (be patient)...
svn: E170013: Unable to connect to a repository at URL 'https://github.com/OSGeo/grass-addons/branches/grass8/src/raster/r.clip'
svn: E160013: '/OSGeo/grass-addons/branches/grass8/src/raster/r.clip' path not found
ERROR: GRASS Addons <r.clip> not found
Do you know what the problem is?
Mario Reyes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240115/416a8b0f/attachment-0001.htm>
Name: Product at 2x.png
Type: image/png
Desc: Product at 2x.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240115/416a8b0f/attachment-0002.png>
Type: image/png
Desc: cropped-github-favicon-512.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240115/416a8b0f/attachment-0003.png>
