[GRASS-user] Installing addons in GRASS 8.2.0 - Ubuntu 22.04.3 LTS
Veronica Andreo
veroandreo at gmail.com
Tue Jan 16 11:50:23 PST 2024
Hola Mario,
You could download the r.clip folder to your disk and install the extension
using the path to the folder. Something like: g.extension extension=r.clip
url=path/to/folder/r.clip
hth,
Vero
El lun, 15 ene 2024 a las 20:09, Edouard Choinière via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hi!
> This problem seems to have been fixed proactively 10 months ago in
> https://github.com/OSGeo/grass/pull/2895
> <https://github.com/OSGeo/grass/pull/2895> and released in Grass 8.3.0 on
> June 24. 2023.
> GitHub announced last year that it was sunsetting SVN protocol access, and
> has been sunset on January 8 2024. So it’s expected that the installation
> using an now in existing url won’t work.
> [image: Product at 2x.png]
> Sunsetting Subversion support
> <https://github.blog/2023-01-20-sunsetting-subversion-support/>
> github.blog
> Subversion has been sunset
> <https://github.blog/changelog/2024-01-08-subversion-has-been-sunset/>
> github.blog
> [image: cropped-github-favicon-512.png]
> Apart from using 8.3.0+, like from
> https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable, I
> don’t remember the specific workaround to specify an alternative url that
> won’t use the SVN code path for code stored in GitHub.
> Can someone step in?
> Edouard Choinière
> Le 15 janv. 2024 à 07:52, Mario Reyes <ernestoreyes561 at gmail.com> a
> écrit :
> Hi,
> I want to install the r.clip addon in Ubuntu 22.04.3 LTS. I am using GRASS
> 8.2.0, installed from
> https://launchpad.net/%7Eubuntugis/+archive/ubuntu/ppa. I also installed
> svn and grass-dev. When I use g.extension I get the following error:
> g.extension r.clip
> /usr/lib/grass82/scripts/g.extension:167: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
> from distutils.dir_util import copy_tree
> Fetching <r.clip> from GRASS GIS Addons repository (be patient)...
> svn: E170013: Unable to connect to a repository at URL 'https://github.com/OSGeo/grass-addons/branches/grass8/src/raster/r.clip'
> svn: E160013: '/OSGeo/grass-addons/branches/grass8/src/raster/r.clip' path not found
> ERROR: GRASS Addons <r.clip> not found
> Do you know what the problem is?
> Mario Reyes
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240116/25062800/attachment-0001.htm>
Name: Product at 2x.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240116/25062800/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240116/25062800/attachment-0003.png>
