[GRASS-user] Status of ITZI in GRASS?
Thomas Adams
tea3rd at gmail.com
Wed Jul 31 12:26:29 PDT 2024
Hi all;
I have tried both approaches suggested by Venka and Markus and keep getting
errors; I have:
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
and I get this:
cython -3 itzi/swmm/swmm_c.pyx itzi/flow.pyx
/usr/lib/python3/dist-packages/scipy/__init__.py:146: UserWarning: A NumPy
version >=1.17.3 and <1.25.0 is required for this version of SciPy
(detected version 2.0.0
I also have to use python3 not python in...
python setup.py build
Also, when I tried the approach suggested by Venka using conda, this messed
up my GRASS installation with wxpython and the GUI would not launch. So, I
had to remove conda and install wxpython
A couple of years ago with a different Linux system and Itzi installed
fine, so this is quite frustrating
Tom
On Thu, Jun 13, 2024 at 8:19 PM Venka via grass-user <
grass-user at lists.osgeo.org> wrote:
> Hi,
> Thanks to Markus and Song for their feedback.
> We succeeded in installing ITZI on Ubuntu 22.04
> Steps to install GRASS and ITZI are as below;
> ############ Install GRASS
> #adding GRASS repository into ubuntu22.04
> #https://grass.osgeo.org/download/linux/#GRASS-GIS-current
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> sudo apt update
> #installing GRASS 8.3.2
> sudo apt-get install grass
> #check grass well-done?
> grass -v
> grass -h
> ########### Python virtual environment
> conda info --envs
> #conda create --name py38venka python=3.8
> conda create --name py310venka python=3.10
> conda activate py310venka
> conda info --envs
> ############installing itzi
> https://itzi.readthedocs.io/en/latest/installation.html#installation-on-gnu-linux
> #numpy required
> conda install -c conda-forge pysal rioxarray cartopy
> #cython, setuptools required
> conda install -c conda-forge setuptools cython
> #Compiling itzi first
> unzip itzi-20.5.zip
> cd itzi-master
> python setup.py install
> Best,
> Venka
> On 6/14/2024 1:55 AM, Markus Neteler via grass-user wrote:
> > Hi,
> > FWIW, I was able to compile ITZI today on Fedora 39 (gcc version
> > 13.3.1 20240522; Python 3.12.3), using
> > # install dependencies
> > pip install numpy setuptools cython
> > # generate some needed C files
> > # build
> > # install
> > python setup.py install --user
> > # test if it starts
> > itzi version
> > 20.5
> > # pytest (see docs/prog_manual.rst)
> > pytest -v
> > Due to lack of time I could not continue yet.
> > Perhaps I can try these days during the
> > https://grasswiki.osgeo.org/wiki/GRASS_Community_Meeting_Prague_2024
> > Best
> > Markus
> > Markus Neteler, PhD
> > https://www.mundialis.de - company
> > https://grass.osgeo.org - FOSS
> > https://neteler.org - freelancing & blog
> > grass-user mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240731/dabd019a/attachment.htm>
