[GRASS-user] Status of ITZI in GRASS?
Thomas Adams
tea3rd at gmail.com
Tue Jun 4 07:33:34 PDT 2024
Hi all!
I am wondering if anyone knows of the status of ITZI <https://www.itzi.org/>
, a GIS model for urban floods simulations using GRASS? The source is
located here <https://github.com/ItziModel/itzi>.
I tried compiling/installing on Ubuntu 22.04 with GRASS 8.3, which failed.
I sent an email to the developer without a response
Any thoughts?
Best,
Tom
The error...
sudo pip install -U itzi
Collecting itzi
Using cached itzi-20.5.tar.gz (652 kB)
Preparing metadata (setup.py) ... done
Requirement already satisfied: grass-session in
/root/.local/lib/python3.10/site-packages (from itzi) (0.5)
Requirement already satisfied: networkx==1.11 in
/root/.local/lib/python3.10/site-packages (from itzi) (1.11)
Requirement already satisfied: pyinstrument in
/root/.local/lib/python3.10/site-packages (from itzi) (4.6.2)
Requirement already satisfied: decorator>=3.4.0 in
/usr/lib/python3/dist-packages (from networkx==1.11->itzi) (4.4.2)
Building wheels for collected packages: itzi
Building wheel for itzi (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [157 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.10
creating build/lib.linux-x86_64-3.10/benchmarks
copying benchmarks/__init__.py ->
copying benchmarks/time_benchmark.py ->
creating build/lib.linux-x86_64-3.10/itzi
copying itzi/drainage.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/parser.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/infiltration.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/__init__.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/rasterdomain.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/itzi_error.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/const.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/itzi.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/gis.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/messenger.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/simulation.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/massbalance.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/configreader.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/hydrology.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/surfaceflow.py -> build/lib.linux-x86_64-3.10/itzi
copying itzi/bmi_itzi.py -> build/lib.linux-x86_64-3.10/itzi
creating build/lib.linux-x86_64-3.10/itzi/swmm
copying itzi/swmm/__init__.py -> build/lib.linux-x86_64-3.10/itzi/swmm
copying itzi/swmm/structs.py -> build/lib.linux-x86_64-3.10/itzi/swmm
copying itzi/swmm/swmm_error.py -> build/lib.linux-x86_64-3.10/itzi
/swmm
copying itzi/swmm/swmm.py -> build/lib.linux-x86_64-3.10/itzi/swmm
running egg_info
writing itzi.egg-info/PKG-INFO
writing dependency_links to itzi.egg-info/dependency_links.txt
writing entry points to itzi.egg-info/entry_points.txt
writing requirements to itzi.egg-info/requires.txt
writing top-level names to itzi.egg-info/top_level.txt
reading manifest file 'itzi.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
adding license file 'LICENSE'
writing manifest file 'itzi.egg-info/SOURCES.txt'
copying itzi/flow.c -> build/lib.linux-x86_64-3.10/itzi
copying itzi/flow.pyx -> build/lib.linux-x86_64-3.10/itzi
creating build/lib.linux-x86_64-3.10/itzi/data
copying itzi/data/VERSION -> build/lib.linux-x86_64-3.10/itzi/data
copying itzi/data/example.ini -> build/lib.linux-x86_64-3.10/itzi/data
copying itzi/data/out_20.5 -> build/lib.linux-x86_64-3.10/itzi/data
copying itzi/data/tutorial.ini -> build/lib.linux-x86_64-3.10/itzi
/data
creating build/lib.linux-x86_64-3.10/itzi/data/colortable
copying itzi/data/colortable/default.txt ->
copying itzi/data/colortable/depth.txt -> build/lib.linux-x86_64-3.10/
copying itzi/data/colortable/froude.txt ->
copying itzi/data/colortable/vdir.txt -> build/lib.linux-x86_64-3.10/
copying itzi/data/colortable/velocity.txt ->
copying itzi/swmm/swmm_c.c -> build/lib.linux-x86_64-3.10/itzi/swmm
copying itzi/swmm/swmm_c.pyx -> build/lib.linux-x86_64-3.10/itzi/swmm
creating build/lib.linux-x86_64-3.10/itzi/swmm/source
copying itzi/swmm/source/climate.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/consts.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/controls.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/culvert.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/datetime.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/datetime.h -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/dwflow.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/dynwave.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/enums.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/error.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/error.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/exfil.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/exfil.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/findroot.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/findroot.h -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/flowrout.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/forcmain.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/funcs.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/gage.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/globals.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/gwater.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/hash.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/hash.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/headers.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/hotstart.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/iface.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/infil.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/infil.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/inflow.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/input.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/inputrpt.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/keywords.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/keywords.h -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/kinwave.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/landuse.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/lid.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/lid.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/lidproc.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/link.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/macros.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/massbal.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/mathexpr.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/mathexpr.h -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/mempool.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/mempool.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/node.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/objects.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/odesolve.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/odesolve.h -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/output.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/project.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/qualrout.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/rain.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/rdii.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/report.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/routing.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/runoff.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/shape.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/snow.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/stats.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/statsrpt.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/subcatch.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/surfqual.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/swmm5.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/swmm5.def -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/swmm5.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/table.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/text.h -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/toposort.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/transect.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/treatmnt.c -> build/lib.linux-x86_64-3.10/
itzi/swmm/source
copying itzi/swmm/source/xsect.c -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
copying itzi/swmm/source/xsect.dat -> build/lib.linux-x86_64-3.10/itzi
/swmm/source
running build_ext
compiler: unix
building 'itzi.flow' extension
creating build/temp.linux-x86_64-3.10
creating build/temp.linux-x86_64-3.10/itzi
x86_64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g
-fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat
-Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat
-Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
-I/usr/lib/python3/dist-packages/numpy/core/include
-I/usr/include/python3.10 -c itzi/flow.c -o build/temp.linux-x86_64-3.10/
itzi/flow.o -O3 -w -fopenmp
itzi/flow.c: In function ‘__pyx_tp_dealloc_array’:
itzi/flow.c:23021:5: error: lvalue required as increment operand
23021 | ++Py_REFCNT(o);
itzi/flow.c:23023:5: error: lvalue required as decrement operand
23023 | --Py_REFCNT(o);
itzi/flow.c: In function ‘__pyx_tp_dealloc_memoryview’:
itzi/flow.c:23332:5: error: lvalue required as increment operand
23332 | ++Py_REFCNT(o);
itzi/flow.c:23334:5: error: lvalue required as decrement operand
23334 | --Py_REFCNT(o);
itzi/flow.c: In function ‘__pyx_tp_dealloc__memoryviewslice’:
itzi/flow.c:23582:5: error: lvalue required as increment operand
23582 | ++Py_REFCNT(o);
itzi/flow.c:23584:5: error: lvalue required as decrement operand
23584 | --Py_REFCNT(o);
error: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a
problem with pip.
ERROR: Failed building wheel for itzi
Running setup.py clean for itzi
Failed to build itzi
Installing collected packages: itzi
Running setup.py install for itzi ... error
× Running setup.py install for itzi did not run successfully.
│ exit code: 1
╰─> [159 lines of output]
running install
/usr/lib/python3/dist-packages/setuptools/command/install.py:34:
SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and
pip and other standards-based tools.
warnings.warn(
running build
running build_py
creating build
/swmm
running egg_info
/data
/swmm/source
/swmm/source
itzi/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
/swmm/source
itzi/swmm/source
itzi/swmm/source
itzi/swmm/source
/swmm/source
/swmm/source
running build_ext
compiler: unix
[end of output]
problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> itzi
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240604/9e3f5bcc/attachment-0001.htm>
