[GRASS-user] Status of ITZI in GRASS?
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Wed Jun 12 00:35:08 PDT 2024
Hi Tom,
I used Itzi sometime late 2022, so that was on Ubuntu 22.04. However, the error you report is most likely due to an update to gcc (less lenient now). I would suggest you start by trying to compile Itzi from source. If that does not work you will need to try it with an older environment (with a gcc version from two years ago or so).
Regards.
Luís
Sent with [Proton Mail](https://proton.me/) secure email.
On Tuesday, 4 June 2024 at 16:33, Thomas Adams via grass-user <grass-user at lists.osgeo.org> wrote:
> Hi all!
> I am wondering if anyone knows of the status of [ITZI](https://www.itzi.org/) , a GIS model for urban floods simulations using GRASS? The source is located [here](https://github.com/ItziModel/itzi).
> I tried compiling/installing on Ubuntu 22.04 with GRASS 8.3, which failed. I sent an email to the developer without a response
> Any thoughts?
> Best,
> Tom
> The error...
> sudo pip install -U itzi
> Collecting itzi
> Using cached itzi-20.5.tar.gz (652 kB)
> Preparing metadata (setup.py) ... done
> Requirement already satisfied: grass-session in /root/.local/lib/python3.10/site-packages (from itzi) (0.5)
> Requirement already satisfied: networkx==1.11 in /root/.local/lib/python3.10/site-packages (from itzi) (1.11)
> Requirement already satisfied: pyinstrument in /root/.local/lib/python3.10/site-packages (from itzi) (4.6.2)
> Requirement already satisfied: decorator>=3.4.0 in /usr/lib/python3/dist-packages (from networkx==1.11->itzi) (4.4.2)
> Building wheels for collected packages: itzi
> Building wheel for itzi (setup.py) ... error
> error: subprocess-exited-with-error
> × python setup.py bdist_wheel did not run successfully.
> │ exit code: 1
> ╰─> [157 lines of output]
> running bdist_wheel
> running build
> running build_py
> creating build
> creating build/lib.linux-x86_64-3.10
> creating build/lib.linux-x86_64-3.10/benchmarks
> copying benchmarks/__init__.py -> build/lib.linux-x86_64-3.10/benchmarks
> copying benchmarks/time_benchmark.py -> build/lib.linux-x86_64-3.10/benchmarks
> creating build/lib.linux-x86_64-3.10/itzi
> copying itzi/drainage.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/parser.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/infiltration.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/__init__.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/rasterdomain.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/itzi_error.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/const.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/itzi.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/gis.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/messenger.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/simulation.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/massbalance.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/configreader.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/hydrology.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/surfaceflow.py -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/bmi_itzi.py -> build/lib.linux-x86_64-3.10/itzi
> creating build/lib.linux-x86_64-3.10/itzi/swmm
> copying itzi/swmm/__init__.py -> build/lib.linux-x86_64-3.10/itzi/swmm
> copying itzi/swmm/structs.py -> build/lib.linux-x86_64-3.10/itzi/swmm
> copying itzi/swmm/swmm_error.py -> build/lib.linux-x86_64-3.10/itzi/swmm
> copying itzi/swmm/swmm.py -> build/lib.linux-x86_64-3.10/itzi/swmm
> running egg_info
> writing itzi.egg-info/PKG-INFO
> writing dependency_links to itzi.egg-info/dependency_links.txt
> writing entry points to itzi.egg-info/entry_points.txt
> writing requirements to itzi.egg-info/requires.txt
> writing top-level names to itzi.egg-info/top_level.txt
> reading manifest file 'itzi.egg-info/SOURCES.txt'
> reading manifest template 'MANIFEST.in'
> adding license file 'LICENSE'
> writing manifest file 'itzi.egg-info/SOURCES.txt'
> copying itzi/flow.c -> build/lib.linux-x86_64-3.10/itzi
> copying itzi/flow.pyx -> build/lib.linux-x86_64-3.10/itzi
> creating build/lib.linux-x86_64-3.10/itzi/data
> copying itzi/data/VERSION -> build/lib.linux-x86_64-3.10/itzi/data
> copying itzi/data/example.ini -> build/lib.linux-x86_64-3.10/itzi/data
> copying itzi/data/out_20.5 -> build/lib.linux-x86_64-3.10/itzi/data
> copying itzi/data/tutorial.ini -> build/lib.linux-x86_64-3.10/itzi/data
> creating build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/data/colortable/default.txt -> build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/data/colortable/depth.txt -> build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/data/colortable/froude.txt -> build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/data/colortable/vdir.txt -> build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/data/colortable/velocity.txt -> build/lib.linux-x86_64-3.10/itzi/data/colortable
> copying itzi/swmm/swmm_c.c -> build/lib.linux-x86_64-3.10/itzi/swmm
> copying itzi/swmm/swmm_c.pyx -> build/lib.linux-x86_64-3.10/itzi/swmm
> creating build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/climate.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/consts.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/controls.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/culvert.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/datetime.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/datetime.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/dwflow.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/dynwave.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/enums.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/error.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/error.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/exfil.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/exfil.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/findroot.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/findroot.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/flowrout.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/forcmain.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/funcs.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/gage.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/globals.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/gwater.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/hash.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/hash.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/headers.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/hotstart.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/iface.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/infil.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/infil.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/inflow.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/input.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/inputrpt.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/keywords.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/keywords.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/kinwave.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/landuse.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/lid.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/lid.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/lidproc.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/link.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/macros.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/massbal.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/mathexpr.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/mathexpr.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/mempool.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/mempool.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/node.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/objects.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/odesolve.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/odesolve.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/output.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/project.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/qualrout.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/rain.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/rdii.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/report.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/routing.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/runoff.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/shape.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/snow.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/stats.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/statsrpt.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/subcatch.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/surfqual.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/swmm5.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/swmm5.def -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/swmm5.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/table.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/text.h -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/toposort.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/transect.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/treatmnt.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/xsect.c -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> copying itzi/swmm/source/xsect.dat -> build/lib.linux-x86_64-3.10/itzi/swmm/source
> running build_ext
> compiler: unix
> building 'itzi.flow' extension
> creating build/temp.linux-x86_64-3.10
> creating build/temp.linux-x86_64-3.10/itzi
> x86_64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/lib/python3/dist-packages/numpy/core/include -I/usr/include/python3.10 -c itzi/flow.c -o build/temp.linux-x86_64-3.10/itzi/flow.o -O3 -w -fopenmp
> itzi/flow.c: In function ‘__pyx_tp_dealloc_array’:
> itzi/flow.c:23021:5: error: lvalue required as increment operand
> 23021 | ++Py_REFCNT(o);
> itzi/flow.c:23023:5: error: lvalue required as decrement operand
> 23023 | --Py_REFCNT(o);
> itzi/flow.c: In function ‘__pyx_tp_dealloc_memoryview’:
> itzi/flow.c:23332:5: error: lvalue required as increment operand
> 23332 | ++Py_REFCNT(o);
> itzi/flow.c:23334:5: error: lvalue required as decrement operand
> 23334 | --Py_REFCNT(o);
> itzi/flow.c: In function ‘__pyx_tp_dealloc__memoryviewslice’:
> itzi/flow.c:23582:5: error: lvalue required as increment operand
> 23582 | ++Py_REFCNT(o);
> itzi/flow.c:23584:5: error: lvalue required as decrement operand
> 23584 | --Py_REFCNT(o);
> error: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
> [end of output]
> note: This error originates from a subprocess, and is likely not a problem with pip.
> ERROR: Failed building wheel for itzi
> Running setup.py clean for itzi
> Failed to build itzi
> Installing collected packages: itzi
> Running setup.py install for itzi ... error
> × Running setup.py install for itzi did not run successfully.
> │ exit code: 1
> ╰─> [159 lines of output]
> running install
> /usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
> warnings.warn(
> running build
> running build_py
> creating build
> running egg_info
> running build_ext
> compiler: unix
> [end of output]
> error: legacy-install-failure
> × Encountered error while trying to install package.
> ╰─> itzi
> note: This is an issue with the package mentioned above, not pip.
> hint: See above for output from the failure.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240612/689cea17/attachment-0001.htm>
