[GRASS-user] Vector import
Stuart Edwards
sedwards at verdantenv.com
Thu Jun 27 07:42:38 PDT 2024
In my last post I was erroneously addressing row 7 instead of 8 ......
After another shut down and restart, the problem has mysteriously solved itself and the file imports as expected - spaces and all.
Very strange.
Stu
On Jun 27 2024, at 10:19 am, Stuart Edwards via grass-user <grass-user at lists.osgeo.org> wrote:
> Hi --
> I hate to complain because GRASS is such amazing value and I have counted on it for about 20years. However this puzzle seems to be something that just shouldn't happen. Importing ASCII files has always (for me) been a challenge. Much as I might try, there always seems to be something wrong with my files. Here's a case in point. Simple table with 6 columns and 66 rows - copy attached. This was output from R - which is usually very reliable.
> v.in.ascii thinks otherwise..... In the clip you can see that row 8 was broken and only 5 columns detected. Rows 1-7 with identical (to my eyes) formatting are not rejected. But perhaps it doesn't like the space in the geology column string (even though 1-7 all include at least one space) . Replace the space with an _ and try again. No luck. Get rid of the space completely. No luck. Try reading the file back into R - no problem. Try reading the file into QGIS - no problem.
> So that's my puzzle for today. If anyone can see where the problem lies - that would be great.
> I'm running GRASS 8.4 on a 2014 MacBook Pro with OSX 11.7.10.
> Best regards
> Stu
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240627/7b02ccd3/attachment.htm>
