[GRASS-user] i.sentinel add-on incomplete in WinGrass 8.4?
Vishal Mehta
vishalm1975 at gmail.com
Thu Oct 10 10:45:35 PDT 2024
Hi Veronica, all,
How can I start using i.eodag? This is my system:
GRASS version: 8.4.0
Code revision: e49c044e62
Build date: 2024-07-28
Build platform: x86_64-w64-mingw32
GDAL: 3.9.1
PROJ: 9.4.0
GEOS: 3.12.2
SQLite: 3.45.1
Python: 3.12.4
wxPython: 4.2.1
Platform: Windows-10-10.0.19044-SP0
On Tue, Aug 27, 2024 at 12:18 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Vishal,
> In any case, please notice that i.sentinel.download received significant
> changes lately given that sentinelsat was no longer maintained and Sentinel
> data was moved from the Copernicus Open Access Hub to the Copernicus Data
> Space Ecosystem. i.sentinel.download now depends on i.eodag extension and
> EODAG library [1,2]. So, since i.sentinel.coverage uses i.sentinel.download
> as I am realizing now, it will probably need to be reviewed at least.
> I'm putting Hamed in cc here, as he was the GSoC contributor working on
> the updates.
> Best,
> Vero
> [1] https://grass.osgeo.org/grass84/manuals/addons/i.eodag.html
> [2] https://eodag.readthedocs.io/en/stable/
> El mar, 27 ago 2024 a las 4:07, Markus Neteler via grass-user (<
> grass-user at lists.osgeo.org>) escribió:
>> Hi Vishal,
>> (cc Martin who maintains the wingrass server)
>> Good catch.
>> On Tue, Aug 27, 2024 at 4:10 AM Vishal Mehta via grass-user
>> <grass-user at lists.osgeo.org> wrote:
>> > Hi,
>> > I wanted to try out the sentinel toolset, trying to follow :
>> > https://training.gismentors.eu/grass-gis-workshop-jena/units/20.html
>> > However, the i.sentinel extension seems to be missing
>> i.sentinel.coverage:
>> > https://wingrass.fsv.cvut.cz/grass84/addons/grass-8.4.0/
>> > Any idea if that can be added?
>> There seems to be some issue on the wingrass server:
>> --> Windows log files
>> Basically all jobs fail with:
>> Traceback (most recent call last):
>> File "C:\Users\landamar\grass_packager\grass84\addons\db.join\scripts\
>> db.join.py",
>> line 64, in <module>
>> import grass.script as grass
>> ModuleNotFoundError: No module named 'grass'
>> Needs to be investigated on the server (I don't have access) by Martin.
>> Best
>> Markus
>> Markus Neteler, PhD
>> https://www.mundialis.de - company
>> https://grass.osgeo.org - FOSS
>> https://neteler.org - freelancing & blog
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Dra. Verónica Andreo
> Investigadora Adjunta de CONICET
> Instituto Gulich (CONAE - UNC)
> Centro Espacial Teófilo Tabanera (CETT)
> Falda del Cañete - Córdoba, Argentina
> +54 3547 400000 int. 1153
> https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20241010/b7c146e0/attachment.htm>
